It is currently Thu Sep 29, 2022 8:09 am
 Post subject: ac/ps brackets
PostPosted: Mon Jul 25, 2022 3:49 pm
I have a 78 slant/6 drivetrain in a 50 Plymouth. I need the mounts for a small AC compressor (sanden?) and if possible a bracket to mount a smaller Power Steering pump. Also looking for the small gear driven starter or the info on make/model/year that will fit a 904 automatic. And finally the linkages for the carb and trans or info on cable linkage.
Life is good!
 Post subject: Re: ac/ps brackets
PostPosted: Mon Jul 25, 2022 4:24 pm
Lots of people wanting A/C brackets lately
PostPosted: Tue Jul 26, 2022 12:14 pm
The compatible ultra-compact starter is this one, installed with a minor/easy modification shown here and in this thread.
PostPosted: Wed Sep 14, 2022 4:28 pm
Car Model: 78’ dodge D100 slant six
Thanks Dan. Will this work in a 78 d100 slant as well?
PostPosted: Wed Sep 14, 2022 4:46 pm
I put a mini starter from a 91, 318 Dakota onto my slant in my 85 pick up. It bolted right up, by the starter is "clocked" different than the old style starter, the wire terminals are rotated inward toward the block more. It works great but I don't like it because I like the sound of the original style, it's what I grew up with, the telltale sign that "some kind of Dodge" was starting up out on the parking lot. You know that sound, you couldn't mistake it for any other brand, and you could hear it 10 rows over from wherever you were at
I used that one only because it's what I had laying around here..... I just parted out the donor truck about a month ago.
PostPosted: Wed Sep 14, 2022 4:53 pm
The OP doesn't mention what exhaust he is using. Yeah if hyper pak and/or Dutra duals he may well have to run the super mini. Never played with anything but standard stock original exhaust manifolds on a slant----- as of yet/ so far anyway.
And yeah either starter mentioned will work for a /6 in a 78 pickup for whoever asked.
