It is currently Thu Nov 26, 2020 10:19 am
PostPosted: Sat Sep 26, 2020 4:38 am
Car Model: 1966 Dodge Dart 170
I am in need of a power steering pump pulley for a TRW pump. The pulley needs to be offset like the one in the attached picture.
File comment: Offset pulley for trw pump
PostPosted: Sat Sep 26, 2020 11:03 am
Not just the pulley is different for use with A/C, but so is the bracket.
PostPosted: Sat Sep 26, 2020 4:22 pm
Do you have a picture? I think I can modify my bracket but would rather have an original.
PostPosted: Sun Oct 04, 2020 8:58 am
Car Model: 1966 Plymouth Valiant
@Studebaker I have an unorthodox solution that I discovered once upon a season that has worked for me.
My original thompson pulley for that pump was pretty badly damaged for reasons unknown. Also an AC car with the offset.
What I found that WORKED, was taking an old GM v-belt power steering pulley, having a machine shop hog the OD of the shaft hole to match the thompson, flipping it backwards, and installing that. The pulley size and offset is almost spot-on when installed backwards.
cron
