It is currently Thu Nov 26, 2020 10:11 am
 Post subject: 742 case needed
PostPosted: Sun Oct 18, 2020 12:34 pm
I have a good (empty) 489 case for an 8 3/4" rear. I need a 742 case in the same condition. Anyone have one they want to swap. It would be nice if it was on the east coast somewhere.
Drop me a PM
2 Mopars come with Spark plug tubes. One is a highly refined, world class, racing machine. The other is a 426 CI. boat anchor!
 Post subject: Re: 742 case needed
PostPosted: Thu Oct 29, 2020 8:02 am
Bump
PostPosted: Thu Oct 29, 2020 8:21 am
I bet if you put this same request of FABO you will find one.
Cheers!
Greg Ondayko
PostPosted: Thu Oct 29, 2020 10:41 am
I thought that the 489 was the"good" one that everyone wants?
PostPosted: Thu Oct 29, 2020 10:57 am
Its debatable..
He obviously needs a 742.. i have invested in 489.
I think the 742 was the version that they made the aluminum case for!
Greg Ondayko
PostPosted: Thu Oct 29, 2020 1:23 pm
It's been too long since I have messed with an 8-3/4, my CRS is messing with me now.
PostPosted: Thu Oct 29, 2020 2:14 pm
http://www.doctordiff.com/blog/tech-inf ... omparison/
I was reading this recently.. And Was thinking about how I invested in almost all 489 Stuff.
Greg Ondayko
PostPosted: Thu Oct 29, 2020 5:00 pm
I have a set of gears for the 742 case.
PostPosted: Fri Oct 30, 2020 3:41 am
I have a few 741s too, which are perfectly fine for anything we will throw at them, with very few exceptions.
"You mean you still have a Slant 6 in that thing?"
PostPosted: Fri Oct 30, 2020 6:06 am
Car Model: More than I should have...
When I was moving my junk to the big garage I saw a chunk of metal that looked like a center section... I'll look more closely and let ya know. :wink:
Drag Racing
Commentator/
Points Keeper
PostPosted: Fri Oct 30, 2020 6:09 am
Thanks for the link to the DrDiff article. Makes sense to me.
His article on Green bearings also jives with my feelings and experiences. I have seen zero problems with those and do not hesitate to use them. NOTE that I have cut/sanded down a few axle ends to make SURE there is no side preload on the bearings.
PostPosted: Fri Oct 30, 2020 6:46 am
Eliminate Preload for the greens!
Greg Ondayko
PostPosted: Fri Nov 20, 2020 1:51 pm
[quote]When I was moving my junk to the big garage I saw a chunk of metal that looked like a center section[/quote
Let me know what you find!
PostPosted: Sat Nov 21, 2020 11:20 pm
I'm in the process of putting together a 742 right now. It's a little easier to do a 742 than a 489, but not enough to worry about.
Getting a solid spacer to replace the crush sleeve on the 489 makes it much nicer.
I have a 741 3.91 SG that I have beat on for years. It took the brunt of all my spray antics even with a trans brake. Never hurt it a bit. :mrgreen:
PostPosted: Sun Nov 22, 2020 4:57 am
I have all 3! :D 3.91 & 3.23 are -741, 3.55 & 4.30 are 489, and the 4.56 & 4.86 are 742.
