It is currently Wed Jul 06, 2022 9:28 am
 Post subject: used cams
PostPosted: Fri Apr 08, 2022 7:27 pm
any one with a mech flat tap cam with damaged gear drive in .525 to .540 lift range i could use with external oil pump and stock dist drive?
 Post subject: Re: used cams
PostPosted: Fri Apr 08, 2022 9:27 pm
I have one of the Mopar 528 cams that ate the oil pump at 800 miles. It's in a box at my shop. I can look at it next time I'm down there.
PostPosted: Sat Apr 09, 2022 6:17 pm
ok! thanks!
PostPosted: Sat Apr 09, 2022 8:24 pm
If the oil pump drive gear is damaged, how are you going to drive the stock distributor?
66 Valiant Signet 225 nitrous
PostPosted: Sun Apr 10, 2022 6:41 am
if it only ate one oil pump gear usually still good to drive the dist!
PostPosted: Sun Apr 10, 2022 6:52 am
The same gear on the cam, drives both the oil pump and the distributor.
If you're saying it just ate the gear on the oil pump, but the cam is still ok, then why change the cam?
I'm having trouble understanding what you are trying to do.
PostPosted: Sun Apr 10, 2022 1:50 pm
sorry! i have a belt drive oil pump ! had my .528 cam in it and lost the wall in the exhaust port on my over ported head, antifreeze in the oil wiped two lobes! was looking for a cheaper option than ordering new if i could make it work! my 528 cam also hurt the oil pump gear! that is why i was using a external pump!
PostPosted: Mon May 09, 2022 3:58 pm
Sorry it took so long. Found the cam but the gear has 2 teeth completely broken. No way would it drive the distributor.
PostPosted: Mon May 09, 2022 6:20 pm
Time for external oil pump and micro squirt/ mega squirt...
PostPosted: Tue May 10, 2022 5:28 am
haha! i have the external pump covered!
