It is currently Sun May 05, 2024 8:23 am
PostPosted: Sat Mar 09, 2024 10:33 pm
Car Model: 1965 Valiant 200 Convertible Super 6 with A/C
Hello,
I'm looking for the spindles for a Kesley-Hayes front disk brake setup.
One of my spindles has a strange wear mark where the wheel bearing seal rides.
Thanks
PostPosted: Wed Mar 13, 2024 4:13 pm
If the mark you are seeing is wear from the seal, you could have it filled with braise and then precision machined back to size - roundness. If you don’t plan to put 50,000 miles on the car you could fill the trough with a sturdy metal filled epoxy and hand file it back round.
PostPosted: Wed Mar 13, 2024 9:51 pm
Speedi Sleeve available?
PostPosted: Thu Mar 14, 2024 5:42 am
Online
Those spindles **might** interchange with the 10" front drum Spindles. Possibly would need to do some re drilling for the caliper mounting, I cant recall for sure if this is the case or not.
Check on FABO to confirm or deny my idea.
