It is currently Tue Jun 25, 2024 3:48 pm
PostPosted: Fri May 03, 2024 6:39 pm
I sold my slant six and A904, but duh, I forgot to remove the shift and kickdown levers. See pic below. They are Mopar part numbers 21-142-12 and 21-142-18. Anyone have these?
Brian
https://tinyurl.com/yynpj4v2
PostPosted: Fri May 03, 2024 7:23 pm
Those are not part numbers. They are a reference number. For example in the 1972 parts manual there are 7 different part numbers for 21-142-12 depending on vehicle, engine and trans. For 21-142-18 there are 2 different part numbers depending on whether 904 or 727 trans.
66 Valiant Signet 225 nitrous
PostPosted: Fri May 03, 2024 8:53 pm
OK, does anyone have the shift lever that looks like in the pic? It's not flat, it has a bend in it...and it's longer than the kickdown lever.
PostPosted: Fri May 03, 2024 9:07 pm
Car Model: 1975 Dodge D100
PM sent, Brian,
I have a pair from the 1970 model slant six 904 I swapped for the original 727 in my pickup. I intended to use these with the swap but the shift linkage worked better with the 727 levers so I reused them instead. I didn't find any numbers on these 904 levers, but they look like the ones you have pictured.
1975 Dodge D100 225 c.i., HEI, Parallel Offenhauser, Motorcraft 2150, 904 auto, 9.25" 3.55:1
PostPosted: Sat May 04, 2024 3:54 pm
Got your PM and replied...those look like the ones!
