It is currently Sat Jul 24, 2021 11:29 am
 Post subject: Garage sale
PostPosted: Thu Jun 17, 2021 10:47 am
It is time I bit the bullet. Looking to sell off all my car stuff (and I men ALL) Would prefer to sell as a complete package.
64Valiant 4dr sdn 170 3 speed (runs is registered and driven but still needs work Many parts with it)
65 Valiant 2dr post just a roller with a 3.9 "A" 8 3/4 (don't remember if SG or spool)
64 Valiant was roller but sitting for ever. ( has subframe connectors, springs moved in board, cut for tubs, ) Parts go with car 8 point roll bar kit, 66 Barracuda fiberglass tilt nose (wheel wells moved forward ala altered wheelbase), 66 Barracuda glass doors, 66 Barracuda glass deck lid, glass bumper
66 Valiant Signet race car 170 slant six 904, 3.91 8 3/4 Nitrous fogger system, Race ready except for small oil leak at pass side timing cover/pan joint
84 D100 slant six 833 od 8 3/4 will drive but is ready for clutch (have new clutch)
Many new and used slant six parts, I need to make a complete list, I will keep adding as I find things.
2 new converters, (One Edge, One FTI)
2 good used converters (high stall)
26 torque flite core transmissions of different years and configurations. Including A500 and A518 (Will compile list later)
2 A833od transmissions non "A" body type. Two shifter mounts.
2 A903 slip spline output shaft transmissions
1 A903 flange output shaft trans
1 A230 transmission
set of forged 2.2 turbo pistons with rings
set of 2.2 forged non turbo flattop pistons with valve notches with rings
set of fresh recon and balanced 198 rods with ARP bolts
set of stock 198 rods and ARP bolts (not installed)
Set of new reconditioned cast crank rods with .040 over stock replacement pistons
set of used roller rockers
new stock rocker arms
new solid and hydraulic rocker shafts
Pushrods new and used
Many sets of used rockers, and shafts
2 Cloyes Double roller timing sets
1 JP Performance douple roller timing set
1 Cloyes double roller cam gear
Many sets of main and rod bearings
A few set of rings
5 engine stands with unfinished slant six engines (170, 225)
All my A/C equipment, it is older, but still ok for the hobbiest.
One 134a recovery/recycler
One r12 recovery recycler
One recovery only machine
2 vac pumps
Gauges
Crimp tool for older make up hose crimps
Crimp tool for newer bubble crimp make up hose
Electronic digital dual contact thermometer
Back of my Toyota pickup is filled with older A/C parts for mostly Mopars some new, most used ( evap cases, controls, brackets, pulleys, etc) also new and used fittings, "O" rings, etc. Probably will not do a complete inventory.
Have several aftermarket parallel flow condensers, also electric fans.
66 Valiant Signet 225 nitrous
 Post subject: Re: Garage sale
PostPosted: Thu Jun 17, 2021 11:41 am
I understand if you want to keep it all together, but if you do split it up, I'd be interested in a lot of your engine parts. Especially the 2.2 turbo pistons and 198 rods.
Escape Velocity Racing
PostPosted: Thu Jun 17, 2021 2:37 pm
Is this an all of a sudden thing? Did something happen?
Hope all is alright.
PostPosted: Thu Jun 17, 2021 3:02 pm
I have some heart problems, that are gradually getting worse. My wife has several medical issues, including Alzimers.
If it werent for the time needed to take care of my wife, I could probably still do some car stuff, but that is just taking more and more time. I kept saying I would cut back, keep some stuff, and sell some. But that is not working. So I'm going to list everything for sale (Going to take awhile), before I am unable to, an stuff goes for scrap , if/when I die (not eminent) because someone has no idea of it's value.
And when I say everything, I mean everything, Several tool boxes filled with tools, including machinest measuring tools, air tools, valve and seat grinding machine and auto test and diagnostic equipment much more.
PostPosted: Thu Jun 17, 2021 3:20 pm
Let me get my list done, Then people can see what I have and if they are interested in anything. Maybe a few people get together, buy the lot and each can pick out what they want. Fair warning, probably would take a pretty large truck, I in trans cores, alone there is over thirty. Then blocks, cranks, heads, manifolds, headers, Carbs, etc.
PostPosted: Thu Jun 17, 2021 4:15 pm
I would be interested in the new torque converters, maybe the used, depending on apps.....prayers to You & Your Wife Sir...............
PostPosted: Thu Jun 17, 2021 7:56 pm
yikes..... I see some things on your list (already) that I'd be interested in, but I certainly couldn't take it all..... hope all works out.
"now" I find 198 rods and 2.2 pistons.... grrrr..... too late now (for that project anyways.... ) there's other things on the list that are interesting too.
the 2nd guessing... "project creep".... woulda shoulda coulda...... begins. haha But isn't that always the way?
PostPosted: Fri Jun 18, 2021 3:57 am
I am glad you have posted this, Charlie. I will get the word out at the Wilkesboro race too. This seems like a very sensible decision, although I know it's hard.
A fairly complete list will help greatly. I can help with descriptions when I talk to people.
Warmest wishes to you and Peg,
"You mean you still have a Slant 6 in that thing?"
PostPosted: Sat Jun 19, 2021 1:41 am
Sorry to hear about all the health issues Charlie. This getting old ain't for kids.
If you have a decent Clifford intake I need one to replace the one of Cecil's I got from you. It got stolen last year. (I'm in no hurry)
PostPosted: Mon Jul 05, 2021 5:49 am
Yes Charlie, I too am sorry to hear this but do understand! Old age will catch up to us all and we will all have to cut back sometime. Sending some prayers out for you and Peg. I would be interested in some engine bearings, and maybe some of the machinist stuff if and when you know what you want for things. We all appreciate the knowledge and speed :D You have brought to our sight and racing series. Hope we will still see you around at some events. Take care my friend!
12.80 @ 102.88
PostPosted: Mon Jul 05, 2021 12:54 pm
Thanks for the well wishes.
Keep watching the list as I keep adding stuff.
PostPosted: Tue Jul 20, 2021 10:16 am
Tough thing to go through. I’ve learned from reading your stuff here and abodies. Thanks. I don’t need any parts but interested in the D100 if ya have to separate. Hopefully this will work out for you. Even in hard times there’s blessings to be found. Craig
I'm going to attempt to fix this project and not make it any worse.
