It is currently Fri Dec 02, 2022 11:29 am
PostPosted: Sun Oct 02, 2022 7:27 am
Hello All,
These Bushings are for the automatic transmission and permit the use of a '60-'67 904 Transmission behind a '68-'87 Slant 6 crankshaft.
They work for LA blocks too
$45 - Includes the Shipping.
Thanks,
List: 10/6/22
Walter L.J: 2 Shipped.
Lou: 1 Shipped.
Phillips' 66 1 Shipped.
PostPosted: Wed Oct 05, 2022 9:43 pm
I'll take 2, please.
--Walt Jackson
PostPosted: Wed Oct 05, 2022 11:29 pm
Confirm: works for V8s, too; that changeover started on some V8 engines for '67.
PostPosted: Thu Oct 06, 2022 2:25 am
I would like one please.
"You mean you still have a Slant 6 in that thing?"
PostPosted: Thu Oct 06, 2022 5:29 am
Yes, they work on the LA engine, also
66 Valiant Signet 225 nitrous
PostPosted: Thu Oct 06, 2022 6:00 am
Thanks for the V8 Confirmation.
I dropped off the drawing at the Machine shop down the hill from my house.
The foreman / owner told me ~2 weeks.
I am in no Hurry for them to get completed.
I ordered 10.
3 for you guys here so far 10/6/22 and 1 for a guy on FABO
PostPosted: Sat Oct 22, 2022 7:25 am
Car Model: 1966 DodgeDart
Good Morning
I would also like to purchase one of your adapters also.
Please let me know when they are ready & i will send funds however you prefer
I am in Houston texas
Thank You
1966 Dodge Dart 225
2005 Dodge Dakota 225
PostPosted: Mon Oct 24, 2022 4:04 pm
Rings are done. I will try to pick them up this week.
$45 a piece.
Includes shipping to you.
I will pm you my address for payment
No paypal please,
Just Check or Postal MO
PostPosted: Mon Nov 07, 2022 9:47 pm
Car Model: 1965 Dodge A100
$45 a piece.
No paypal please,
Will this work to adapt a 1968-76 forged crank 225 to an early 727 automatic as well? I'm about to swap the 225 in my 1965 A100 (with the adapter between the 225 & 727) to a 68-76 BH block. If this will work I'd like to pick one of these up from you if you still have any available, please.
Thanks!
Ryan
The Cast Iron Philosopher (Ryan)
I am the Mechanic and my intentions are good.
PostPosted: Tue Nov 08, 2022 6:55 am
Philip's66 wrote:
Good Morning
Thank You
Hello, I have sent you a PM.
PostPosted: Tue Nov 08, 2022 6:57 am
Thanks!
Ryan
I am not sure on that. I am very unfamiliar on the 727 Converter Hubs / Sizes..It could be a non issue..
Will Have to do some research - I don't want to sell you a ring that is not going to be useful for you.
I will check it out.
PostPosted: Tue Nov 08, 2022 7:19 am
Greg asked me to respond.
I don't remember if the factory crank adapter/spacer has a pilot that fits into the crank, or if it fits over the crank flange. If it fits into the crank then the bushing will work. If it fits over the crank flange, you will need to have it machined to the later crank flange diameter, and Gregs adapter is not needed.
PostPosted: Tue Nov 08, 2022 8:02 am
Thanks!
Ryan
Thanks, Greg and Charrlie,
I think I found all my answers here:
viewtopic.php?f=19&t=66205&hilit=1965+225+to+727+adapter
What is outlined on that thread is my exact situation: I've got a 1965 A100 Van with a pre-`68 225 mated to an early A727 with the adapter plate and crank spacer. I'm looking to swap in a `68-76 BH block and keep my early A727. I'm just going to have to machine the crank spacer for the larger diameter flywheel centering ring on the later forged crank. Please correct me if I'm misunderstanding any of this... there's a high probability rate for that. I'm a MoPar Noob.
Thank you, all, for the assistance! I'm sorry for the trouble.
This forum is outstanding. I really appreciate the knowledge and info here.
With gratitude,
Ryan
PostPosted: Tue Nov 08, 2022 8:33 am
This is the correct info
You have a "stock" 65 van with a bad 225 SL6 engine and the original 727 transmission, that uses the adapter plate.
You also have a "good" 76 SL6 engine that you want to install into the van.
So you need to pull out the 65 engine along with the adapter plate, crank extension and flex plate.
Swap all the vans engine mounts, accessories and special parts onto the 76 engine, including the oil pan, the pan's oil pick-up tube and the special adapter plate / crank extension / flex plate that came out of the 65 van...
But...
The 65's crank extension /spacer will not fit onto the 76 crank's pilot hub because the shoulder is larger.
You will have to get the correct crank extension / spacer (68 and later) or have a machine shop open-up the counter bore in the spacer you have so it fits onto the 76 crank.
Once all the needed 65 parts are swapped onto the 76 engine, install the replacement engine into the van and fire it up.
PostPosted: Sun Nov 20, 2022 10:33 am
First batch Sold.. More available if you need one.
Thanks,
cron
