It is currently Tue May 26, 2026 10:09 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: heat riser valve
PostPosted: Sat Aug 04, 2001 12:08 pm
The heat riser valve on my 65 valiant 170 is stuck (What's new). Anyway, I've tried to free it but it's being stubborn. I'm going to upgrade to a super six soon but until then, which position should I leave it stuck in? Towards the block or away from it? Any input?
Thanks
Alex
Orionsax7@cs.com
 Post subject: Re: heat riser valve
PostPosted: Sun Aug 05, 2001 8:11 am
: The heat riser valve on my 65 valiant 170 is
: stuck (What's new). Anyway, I've tried to
: free it but it's being stubborn. I'm going
: to upgrade to a super six soon but until
: then, which position should I leave it stuck
: in? Towards the block or away from it? Any
: input?
: Thanks
: Alex
Not sure towards or away BUT.....
You want it open ...So you want the weight on the end of the shaft at it's lowest point that will be open..... (normaly when the spring gets hot it unloads and the weight pulls it open) Iodine can also help free them up
PostPosted: Sun Aug 05, 2001 9:17 am
: input?
The "flap" or round counter weight will move towards the block, rotate it counter-clockwise.
