It is currently Wed May 27, 2026 4:00 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 19 posts ]  Go to page Previous 1 2
 Post subject: Cheapest 4bbl?
PostPosted: Mon Aug 13, 2001 7:14 am
Thanks for responding, everyone!
What it comes down to is I'm basically looking for inexpensive options to get more performance out of my truck, but if this would take a lot of time to get working, I probably should put the project off until I get out of school. It's looking like it would be more than a weekend project and I actually need to use my truck. Can anyone suggest the easiest way to put a 4bbl on my truck that wouldn't be too expensive (and will pass Texas emissions--it's an '80)?
Thanks again everyone!
Eric
eric.satrum@mail.utexas.edu
 Post subject: Re: Cheapest 4bbl?
PostPosted: Mon Aug 13, 2001 9:03 pm
: Thanks for responding, everyone!
: What it comes down to is I'm basically looking
: for inexpensive options to get more
: performance out of my truck, but if this
: would take a lot of time to get working, I
: probably should put the project off until I
: get out of school. It's looking like it
: would be more than a weekend project and I
: actually need to use my truck. Can anyone
: suggest the easiest way to put a 4bbl on my
: truck that wouldn't be too expensive (and
: will pass Texas emissions--it's an '80)?
Leave the carb. and work on opening-up the exhaust side. Also work on re-curving the distributor. If the truck is a 1 bbl, look for a factory 2 bbl set-up.
PostPosted: Tue Aug 14, 2001 7:47 am
: Leave the carb. and work on opening-up the
: exhaust side. Also work on re-curving the
: distributor. If the truck is a 1 bbl, look
: for a factory 2 bbl set-up.
: DD
I guess I'll start looking for one of those. Thanks, Mr. Dutra!
Eric
 Post subject: Re: Cheapest 4bbl? *NM*
PostPosted: Tue Aug 14, 2001 8:23 am
arollin@ctv.ca
