It is currently Tue Nov 17, 2026 12:10 am
 Post subject: Question of the ages
PostPosted: Wed Apr 26, 2006 8:21 pm
I need help determining what rear-end I have. The car is a Canadian 1970 Dart custom, 225, A904, etc.. It has BBP axles and -if I counted right, a ten-bolt cover with a plug. I'll count the bolts up again tomorrow when my brother brings the car back, but I'm 99.9% sure I remembered all the numbers between one and ten. Sounds like I need to replace me some wheel bearings and I think I'd like to buy some that fit.
Thanks in advance,
Nat
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
PostPosted: Wed Apr 26, 2006 9:03 pm
sounds like a 7 1/4" rear.
-james
PostPosted: Wed Apr 26, 2006 9:32 pm
Sounds a more like an 8¼" rear axle, to me. In any event, it's not original to the car. Got 9" drums or 10" drums on it?
PostPosted: Wed Apr 26, 2006 9:36 pm
Nines. Are the bearing systems the same for the 7 1/4 and 8 1/4? (I mean the sealed bearing and retainer style. Not the sizes) I might just buy both sizes and see which ones fit..... I could always return the ones I don't use...
Thanks,
Nat
 Post subject: 8 1/4??
PostPosted: Sun Apr 30, 2006 10:50 am
Ok, so I think I'm 90% convinced I have an 8 1/4" rear under my dart. (10 bolts, drain plug, cover is not round) Now, does anybody have an exploded diagram of an 8 1/4? Specifically the wheel bearings/axle shafts I'd like to see what the insides look like before I explode the one under the car.
Thanks in advance,
Nat
 Post subject: Re: 8 1/4??
PostPosted: Sat May 06, 2006 9:42 pm
Thanks in advance,
Nat
If you want pictures I have part of a disassembled 8 1/4 in the yard. All I have is the empty housing and axles though. The cover was discarded along with the rusty ring and pinion. All I wanted was the Sure-Grip. PM me and I'll snap some photos.
