It is currently Fri May 15, 2026 8:59 am
PostPosted: Sun Aug 26, 2001 8:48 pm
Master Power Brakes offers a rear disk brake package for the 8.75 rear end. It bolts on in place of the drum brake backing plate.
Is the bolt pattern the same as the 7.25 rear end? That's what I'd like to bolt the package to.
--Walt Jackson
WalterLeeJackson@compuserve.com
PostPosted: Mon Aug 27, 2001 6:14 pm
: Master Power Brakes offers a rear disk brake
: package for the 8.75 rear end. It bolts on
: in place of the drum brake backing plate.
: Is the bolt pattern the same as the 7.25 rear
: end? That's what I'd like to bolt the
: package to.
: --Walt Jackson
If your 7.25 has 10" brakes with the 4-1/2" bolt pattern, you are in business. It should also have 5 studs holding the backing plate on. Mine with 9" brakes and small 4" pattern only have 4.
aschumers@aol.com
