It is currently Fri May 15, 2026 11:54 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: Aluminum 225 weight?
PostPosted: Wed Oct 03, 2001 2:12 pm
Need to ship an aluminum 225 short block (block, crank, cam, timing chain and sprockets, rods, pistons, bearings, bearing caps) and can't access Doug's paper article on the weights of various 6 components (from an old Slant-6 News magazine). Anyone (Doug?) know what this weighs? For that matter, anyone got any bright ideas on how to ship this?
DS
redbear@vrx.net
 Post subject: Re: Aluminum 225 weight?
PostPosted: Wed Oct 03, 2001 3:46 pm
: Need to ship an aluminum 225 short block
: (block, crank, cam, timing chain and
: sprockets, rods, pistons, bearings, bearing
: caps) and can't access Doug's paper article
: on the weights of various 6 components
: (from an old Slant-6 News magazine). Anyone
: (Doug?) know what this weighs? For that
: matter, anyone got any bright ideas on how
: to ship this?
: DS
Dan,
Crank is 75-80 lbs, rods/pistons are 3-3.5 lbs for each set w/bearings + rings, block w/caps should be around 100 lbs, but not totally sure about that. Cam is about 15 lbs. T-chn around 3-5 lbs.
Hope this helps,
madsenl@caltech.edu
PostPosted: Wed Oct 03, 2001 9:50 pm
: Dan,
: Crank is 75-80 lbs, rods/pistons are 3-3.5 lbs
: for each set w/bearings + rings, block
: w/caps should be around 100 lbs, but not
: totally sure about that. Cam is about 15
: lbs. T-chn around 3-5 lbs.
: Hope this helps,
: Lou
My notes and "match-book cover" math came-up with 185 lbs., just a pinch less then what Lou came-up with. (the block with caps is about 88lbs.)
Lou's 200 lbs. would be "safe" for a shipping weight.
