It is currently Mon May 18, 2026 11:07 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: new turbo setup
PostPosted: Tue Oct 09, 2001 4:05 pm
Hey guys its been a while but I have been busy on a new turbo setup. I went to a big .63 a/r to3 turbo and a 600 dp holley, the same intercoolers, a hks blowoff valve, sub frame connectors, mandral bent 3 inch exhaust, and a costom header as soon as I change one pipe around. The car is running but there is some tuning to do. Hopefully it will be in the 14s when its ready.(with stock internals)
andrew wagner
 Post subject: Re: new turbo setup
PostPosted: Tue Oct 09, 2001 4:29 pm
: Hey guys its been a while but I have been busy
: on a new turbo setup. I went to a big .63
: a/r to3 turbo and a 600 dp holley, the same
: intercoolers, a hks blowoff valve, sub frame
: connectors, mandral bent 3 inch exhaust, and
: a costom header as soon as I change one pipe
: around. The car is running but there is some
: tuning to do. Hopefully it will be in the
: 14s when its ready.(with stock internals)
Where did you get your header Andrew? Good luck getting into the 14's!!!!!!!! Dennis
: andrew wagner
aschumers@aol.com
PostPosted: Tue Oct 09, 2001 6:24 pm
I made it myself.
andrew wagner
: Where did you get your header Andrew? Good luck
: getting into the 14's!!!!!!!! Dennis
PostPosted: Fri Dec 28, 2001 9:12 am
Hey Andrew, how some pics of your home made header ?
motorhedfred
: andrew wagner
motorhedfred@yahoo.com
