It is currently Sat May 23, 2026 10:59 pm
PostPosted: Sun Oct 14, 2001 9:25 pm
Hey Group,
Does anyone have any experience with the tighter turning radious manual steering boxes on the (after)market ?
I believe the stock unit on my 64 Dart is 24:1 (5 1/2 turns to lock), and I am thinking of shortening it to 20:1 (4 1/2 turns to lock).
...any suggestions ?
Gina
CarCrazyCutie@headsabove.com
PostPosted: Mon Oct 15, 2001 9:22 am
: Hey Group,
: Does anyone have any experience with the
: tighter turning radious manual steering
: boxes on the (after)market ?
: I believe the stock unit on my 64 Dart is 24:1
: (5 1/2 turns to lock), and I am thinking of
: shortening it to 20:1 (4 1/2 turns to lock).
: ...any suggestions ?
: Gina
Hey Gina,
I have not had personal experience, but I plan to do the 20:1 box on my '64 Dart. Firm Feel ( <A HREF="http://www.firmfeel.com">www.firmfeel.com</A> ) has rebuilt 20:1 chucks for $350 and I've had good luck with them on suspension stuff in the past. A while back, MP used to sell just the 20:1 gear set for about $120 or so.
It will make it harder to steer, which with stock skinny tires will be fine, but if you plan to go to some wider tires, it may get tough. My heavier '68 Dart with a smaller steering wheel (14") and 225/60-14's on the front is somewhat of a handful to parallel park. That's with the stock 24:1 box.
Hope this helps,
madsenl@caltech.edu
PostPosted: Mon Oct 15, 2001 8:32 pm
: Hey Group,
: Gina
Mopar offered 3 ratios with the manual steering boxes:
the 24 to 1 ( really about 5.9 turns "lock-to-lock")
the 20 to 1 @ 4.9 LtoL
and the 16 to 1 @ 3.6 LtoL.
Actually the 3.6 came before the the 4.9, this was the "fast ratio" box for the 60's muscle cars and was quite a hard box to steer, especially in a B-Body with a big block and wide "polyglass" belted tires. (My Dad's 69 Road Runner had this, along with the 4-speed, Mom made him sell the car because she "could not drive it". (but the teenage kids could! =:-O
I think that 3.6 box gave the fast ratio steering option a bad rap because you just do not see many of these fast ratio boxes around, not in the junkyards, not at the swap meets and up untill recently, not offered by the "aftermarket suppliers". I speak from first hand (over hand, over hand,...) knowledge, I have "spun" every Mopar steering box I have come across, 25 years worth, and have only found 3 fast ratios out of hundreds checked. (2 of the 3.6s and one 4.9)
If you really must have a fast ratio, Firm Feel now offers them so just save your $$$ and buy a new one. For the street, I would get the 4.9 turn unit. ( I have to say that I really like the 3.6 I have in my Dragcar. Some people say "what a waste" but the car is light, has skinny front tires, is a breeze to get positioned into the water box or get over to the correct lane and when the "tail wags", it's easer to keep the car out of the wall)
Just for reference, the power steering box has a 15.7 to 1 ratio (about 3.5 turns LtoL) so if you want to get an idea on how a 3.6 box acts, just drive a mopar power steering car around with the belt removed.
From my experience, the only time you really need one of the fast ratio manual boxes is if you slide the car around. (snow, ice, rain, dirt, road course or ??) The rest of the time, it is just a hard way to build-up your arm muscles.
Now,...onto turning radius, yes, there is a "trick" to get your car to turn around in a "smaller" circle. If you look under the car while turning the wheels to full "lock", you will see that the rearward lower ball joint bolt head "stops" up against a bump formed into the end of the lower control arm.
73-76 LCAs had less of a bump. (this was to allow more travel for the "wader track" single piston disc brakes. You don't need to switch LCAs, you can simply grind-off metal to allow more travel. Keep an eye-out that the tire does not bottom-out on the frame rail. Just a littly metal removed makes a difference, I did this to a few of my cars and now they do a "curb to curb" U-turn in my narrow street, without a back-up. :-) Here is where you grind, take some metal off the mating bolt head also.
PostPosted: Tue Oct 16, 2001 9:07 am
: Hey Group,
: Gina
Well, I have a factory fast ratio steering manual gearbox in my 66 Cuda Formula "S" and while I have never yet had the car on the street, turning the wheels in the garage to move the car around has been pretty easy. If you want a faster ratio but are worried about steeering effort you could always convert to power steering but get the steering gearbox out of a diplomat cop car.
Reed
reed@seanet.com
