It is currently Wed Nov 25, 2026 8:53 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Thu Sep 21, 2006 4:10 pm
Yeah, that would be a bad idea; you'd end up with the #6 cylinder going really lean. Personally, I made an EGR block-off plate and then drilled and tapped the vacuum side for a hose barb which handles my PCV.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
