It is currently Sat Jan 11, 2025 3:40 am
 Post subject: 69 to 64 swap
PostPosted: Sun Nov 12, 2006 7:56 pm
Swapping 225 from 69 Dart into 64 valiant that had 170. Both are AT's . 64 is bushbutton and is trans I'll b using w 69 engine....Is there anything that I need to know? I keep reading something about an adapter ring or washer. Thank you
PostPosted: Sun Nov 12, 2006 8:20 pm
You need to put a ¼" adaptor ring in the counterbore of the '69's crankshaft rear flange so that it will mate correctly with the '64's torque converter. Get the ring from Pat Blais, tflitepatty@verizon.net . Also, you'll need to use the '64 oil pan and pickup.
PostPosted: Sun Nov 12, 2006 8:23 pm
Is there ANYWHERE else I can get this ring?
PostPosted: Sun Nov 12, 2006 8:51 pm
Ummm...probably, but why? Pat B is a reliable and reasonably-priced source. If you're asking whether you can buy it locally at a parts store, then the answer is "no".
PostPosted: Sun Nov 12, 2006 9:05 pm
Thank you- Is there another link to him you could give me ? The link isn't working for you
PostPosted: Sun Nov 12, 2006 9:15 pm
It's not a link, it's an e-mail address. Send him e-mail at tflitepatty@verizon.net .
PostPosted: Mon Nov 13, 2006 4:01 am
He does have an Ebay store but I don't believe the ring in question is listed there. As Dan said, the best way to get to him is email. I understand that he is on the road a lot so your chances of catching him live are slim.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
Users browsing this forum: Bing [Bot], Semrush [Bot] and 2 guests
