It is currently Tue Nov 17, 2026 9:08 am
Post new topic  Reply to topic  [ 34 posts ]  Go to page Previous 1 2 3
PostPosted: Thu Nov 16, 2006 3:11 pm
On my 66 A Body AC stuff the heater section is in its own case and the AC stuff is in its own case and the dase can be separated
This argument is semantic. Yes, on the '65-'72 A-body factory A/C, the portion of the underdash housing that holds the A/C evaporator can be separated from the portion that holds the heater core, but they are two parts of a single whole, not two independent housings. Neither one will function correctly without the two parts attached to one another.
PostPosted: Thu Nov 16, 2006 3:13 pm
At last I retrieved the parts, here are some links for the pics of everything I have
None of this stuff is factory equipment. It's all from an aftermarket add-on air conditioner. You're still missing the condenser, the filter-dryer, the expansion valve, the compressor mounting brackets.
PostPosted: Thu Nov 16, 2006 3:21 pm
I'd buy a book on how air conditioning works. This will give you an idea of the up hill battle you have ahead of you.
Or you could go this route.
http://www.renaissanceracing.com/images/RNAC.jpg
PostPosted: Thu Nov 16, 2006 3:28 pm
ja...ja.... very funny, I will look for a book after seeing in A/C installation shops.
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
