It is currently Fri Nov 29, 2024 7:36 pm
PostPosted: Sun Feb 25, 2007 5:58 pm
I am restoring the trunk area in my 74 dart, i had to remove some dried up seam sealer in a few areas, i am looking to recreate the factory look of the seam sealer, does anyone know the proper sealer to use and how to apply it to look factory?
PostPosted: Sun Feb 25, 2007 6:40 pm
I don't have the link, but I'm pretty sure that Eastwood has something that would work. Just google it, and you should find the site. I don't know the proper way to apply...but it doesn't look like they spent much time on it!
Good luck!
225 Cubic Inches of Iron-Head American Muscle
225 bored .040 /.100 off block, Schneider Cam 224@.050~ .480 lift - Stock valves, blended bowls, Offenhauser intake with 500 Edelbrock carb
PostPosted: Sun Feb 25, 2007 6:47 pm
Believe you are after this stuff.
PostPosted: Mon Feb 26, 2007 5:04 am
that stuff that eastwood sells looks more like paint, the stuff that dodge used seemed to be thicker, more rubbery.
PostPosted: Mon Feb 26, 2007 9:00 am
Eastwood have the rubbery stuff, too, as do your local auto body and paint supply store (where the body men go to get their paint and supplies).
PostPosted: Mon Feb 26, 2007 9:13 am
Maybe THIS is what you're looking for?
PostPosted: Mon Feb 26, 2007 12:42 pm
3m and ppg both make several and there are other brands as well. As Dan pointed out go to a auto body paint supply shop. Some come in cans, some in tubes for a chalking gun. The ones I have used are black, tan or white. Just make sure it is a paintable sealer if you ar going to paint over it. Eastwood has some great stuff but some of what they sell are normal body shop supplies and might cost quite a bit less if you source them that way. Quicker too if you can just go pick it up.
PostPosted: Mon Feb 26, 2007 12:59 pm
Yeah, what he said ↑ ↑ ↑
PostPosted: Mon Feb 26, 2007 1:42 pm
Thanks for the tips. I have never used seam sealer before. I dont think this stuff comes out in a caulking gun, it is spread out about 2-3 inches wide, and it is pretty thick, it almost looks like it was sprayed on. I will check with my local body supply
PostPosted: Mon Feb 26, 2007 1:49 pm
I use the 3m fast seal part #08505 works good but you need a calk gun to use it
