It is currently Wed May 20, 2026 1:14 pm
 Post subject: int/exh flange mismatch
PostPosted: Mon Mar 19, 2007 3:45 pm
I'm in the process of match porting my head and I noticed quite a difference between my clifford intake flange .340 thick and my split dual exhaust manifold .515 thick. What do you do about this.Use a spacer on the exhaust
or shave the intake.
I also have a offy intake it measures .520 thick but I was told that a Offy is not as good as a Clifford but I don't have the Experince to say. So I could mount the Offy and the ex manifolds and the thickness is very close.
I also have a set of headers pt#5601H that measure .320 thick which is real close to the Clifford. But after reading Doc's and other articles I just as soon stay away from headers.
So I have many options to choose from. What would be the best combo for me? What would you do?
PostPosted: Mon Mar 19, 2007 3:52 pm
The factory flange thickness is a little over 1/2 inch (.500)
Is your Clifford intake manifold new or used?
PostPosted: Mon Mar 19, 2007 3:57 pm
It is used
PostPosted: Mon Mar 19, 2007 7:04 pm
It is used
Sounds like someone surfaced it to get the manifold to match a thinner header flange.
Time to make some spacers.
Users browsing this forum: 72polara, Bing [Bot], Google [Bot] and 18 guests
