It is currently Thu Oct 15, 2026 11:59 pm
 Post subject: /6 727 lockup torque
PostPosted: Sun Mar 25, 2007 2:37 pm
Car Model: 65 A100 truck
Hello,I picked up an A-100 van in pieces,it came with a fresh /6 long shaft, lockup torque 727,dont know year. My question is,does the converter lock at a pre determined speed internally or is the control electricaly activated ? I know,wrong trans for the short A-100 but this is going in a Ford 1 ton ,dont ask ..lol.. thanks
PostPosted: Sun Mar 25, 2007 8:08 pm
IIRC, all the Slant lockups should be activated through the valve body, no electrics needed. :shock:
PostPosted: Mon Mar 26, 2007 11:07 am
Are you really sure that it's a 727 (not a 904) and that it's got a lockup converter?
PostPosted: Mon Mar 26, 2007 7:52 pm
I have seen a few lockup 727's out of later vans/pickups. If the case has an ear where the dipstick goes in and the input has a pilot on it like a 4 speed trans, it is a 727 lockup. :D
PostPosted: Mon Mar 26, 2007 10:18 pm
Thanks for the replies. Dan ,Im 100% sure its a 727 as i have 5 other /6 727's ,it also has the pilot on the input shaft end.This is the first lockup trans in my collection and was unsure on Its function.
