It is currently Thu Jun 25, 2026 11:57 am
 Post subject: 2.2 Pistons ?
PostPosted: Tue Mar 27, 2007 3:52 pm
I found a reasonable outlet for cast 2.2 turbo pistons. I know that the stock bore for a 2.2 is 87.5mm, which is a hair larger than the stock bore on a slant six. The part # 533P is the stock bore for the 2.2. I have never been any good at the metric system, so I am hoping that someone will be able to help me with the oversize conversion. As I stated the stock part # reads #533P, And the oversize numbers read, #533P50mm, #533P75mm, #533P100mm, and #533P150mm. One can almost be assured that a used block will need to be bored, so if I know how much these size differences are, I will know which one to choose on the over bore. Thanks for the help.
PostPosted: Tue Mar 27, 2007 4:10 pm
The stock 2.2 piston is about 3.44", which would be approximately a 0.040" overbore on the Slant. It's best to have the pistons there when sending the block to the machine shop as they can tailor the clearance to the pistons.
Mike
Recognized by US Federal Courts as a Fuel Economy Expert!
PostPosted: Wed Mar 28, 2007 10:41 am
87.5 = 3.44488
88.0 = 3.46457
88.25 = 3.47441
88.50 = 3.48424
http://www.worldwidemetric.com/metcal.htm
In general, the 2.2 sizes are .005 over SL6 oversizes.
The standard bore 2.2 is .045 oversize, then .065, .075 & .085
As already noted, buy your pistons and measure them before boring & finish honing the block.
PostPosted: Wed Mar 28, 2007 2:47 pm
Thank You Gentlemen!!
 Post subject: Re: 2.2 Pistons ?
PostPosted: Wed Mar 28, 2007 5:32 pm
Car Model: '23 T-bucket
So, ummmm, Dick......You're not going to fill us in on where anyone else might get a set?
Roger
