It is currently Tue May 19, 2026 10:41 pm
PostPosted: Mon Apr 02, 2007 4:47 pm
I ran into a 8 3/4. guy said he thought it was off of a charger maybe? besides shorting the drivshaft will the spring perches be the same? shock mounts? to bad its a 2.76 open posi oh well you cant ask for everything.
71 valiant 225
75 d200 225
93 d200 cummins
PostPosted: Mon Apr 02, 2007 6:55 pm
What's an "open posi?" The Charger is a B-body car; the housing will be wider than you need and the spring perches are not right for an A-body
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Tue Apr 03, 2007 2:29 am
open diff oops
71 valiant 225
75 d200 225
93 d200 cummins
PostPosted: Tue Apr 03, 2007 7:45 am
The B-body axle assembly can be used in an A-body, but you'll need to cut off the spring perches and install a new set in the correct location (and orientation).
PostPosted: Tue Apr 03, 2007 7:58 am
Make sure it is a pre '71 housing. The '71 and up B-bodies got wider and will be way too wide for any kind of decent wheel selection under an A-body. :shock:
PostPosted: Sun May 06, 2007 9:28 pm
Except that the whole axle is 3" wider (68 - 70 B-body) or 6" wider (71-up B-Body). You'll need big backspacing on your wheels.
Users browsing this forum: Ahrefs [Bot] and 4 guests
