It is currently Sun May 24, 2026 12:44 am
 Post subject: Which ATF fluid?
PostPosted: Wed May 29, 2002 3:17 pm
I need to top off my automatic transmission fluid (it's down a pint). The book calls for Type A, but the only thing the parts store sells is Dextron III, Type F, and something made for modern Chryslers. Which one of these should I use to top off my tranmission fluid?
Thanks
 Post subject: Re: Which ATF fluid?
PostPosted: Wed May 29, 2002 7:41 pm
: I need to top off my automatic transmission
: fluid (it's down a pint). The book calls for
: Type A, but the only thing the parts store
: sells is Dextron III, Type F, and something
: made for modern Chryslers. Which one of
: these should I use to top off my tranmission
: fluid?
: Thanks
I've been using Dextron III for years. My '69 service manual says type AQ-ATF, Suffix "A" or "Dextron".
Bob D
BBobbias@aol.com
PostPosted: Wed May 29, 2002 8:21 pm
: fluid?
: Thanks
Dextron III is the "safe bet" if you do not know what type of fluid is in the trans.
In the "racecar" I switched the 904 over to Type F and don't really feel any difference.
PostPosted: Fri May 31, 2002 6:29 am
I also use Dexron III in my '64 A904, but Type A is available here (Lubbock, Texas). Oddly enough, it's in the grocery stores and some discount chains, but not in the parts places.
dobie79423@yahoo.com
PostPosted: Thu Mar 19, 2009 6:49 pm
Will Dexron V work? :?:
PostPosted: Thu Mar 19, 2009 7:32 pm
Yes, Dexron-VI will work (there's no Dexron-V), but Chrysler ATF+4 is my pick of the modern fluids.
PostPosted: Thu Mar 26, 2009 5:12 am
Why ATF+4? Been running type F in the van since the rebuild over 100K ago.
The Cummins has to have +4. The Mopar brand at Wally World was the cheaper bottle!
PostPosted: Thu Mar 26, 2009 9:21 am
Why ATF+4?
Because it is superior to Dexron (-II, -III, -IV) in just about every aspect of transmission fluid performance, and vastly superior to the ancient, primitive Type F fluid.
That's a testament to the mayhem-resistance of a Torqueflite.
PostPosted: Thu Mar 26, 2009 10:44 am
I learned something new the other day- Dexron VI is a slightly lower viscosity (thinner) fluid than Dexron III, ATF+4 isn't. So its probably a better pick than Dexron VI from that regard too.
I doubt anyone would EVER have a problem in a 904 or 727 from using Dex VI- the viscosity difference is very small and those transmissions aren't at all picky.
I've been geeking up on oil tech by reading too much bobistheoilguy.com lately ;-p
PostPosted: Fri Mar 27, 2009 6:11 am
Dexron VI=Dexron 6
Dexron IV=Dexron 4
Is there a 6? Or are you guys not Roman numeral edjumicated? :lol:
PostPosted: Fri Mar 27, 2009 7:17 am
DEXRON VI it is. Maybe IV and V didn't cut the mustard.
mmmmm ... mustard ...
