It is currently Wed Nov 27, 2024 1:35 am
 Post subject: Accelerator Cable
PostPosted: Wed Feb 21, 2007 9:05 am
Edi 2: Thanks Dan, I was able to change my order, I really appreciate it.
Edit: Slant Six Dan figured it out. FYI - Pioneer CA-8417 is the correct accelerator cable for a 2bbl with A/T for $19.09 (or ATP Y-156 $16.24). www.autosupplyco.com use 74 Dart 2bbl 318 for a search vehicle.
Original Post: I am trying to order a new accelerator cable for my super six set up. The part number I come up with is for a 1979 Aspen 2bbl, A/T, Pioneer CA-8415.
Would the 79 Aspen be the right cable for a 2 bbl carter, A/T on a 1970 Dodge Dart Swinger?
I know it seems dumb, but I have come across part number CA-8413 for a 77-78 Aspen.
Has anybody ordered this part before?
My Swinger gets the Highlight Valet Parking spot over the German sports cars on the Sunset Strip. I love my Mopar.
PostPosted: Wed Feb 21, 2007 10:46 am
I do not believe that is correct. The Y163 is 30½" long, which is <i>much</i> too long for a 225-2bbl in an A-body. It also has the square plastic ferrule at the firewall end rather than the round metal one needed for cars made through approximately '77. The factory cable for a 225 2bbl in an A-body (factory equipment outside North America from '67-'76) was the same cable used for a 2bbl V8 in an A-body. Factory P/N 2899 336, 19½" long with round metal ferrule at the firewall end. That cable is an ATP Y156.
Just to round out this list, the Y155 is the A-body 225-1bbl throttle cable (24½" long, round metal ferrule), and Y161 is the short (19¼") cable as used in a 225-2bbl A-body, but with the square plastic ferrule.
PostPosted: Wed Feb 21, 2007 11:51 am
When I couldn't find one in my local parts stores (one place ordered me a square hole kind), I bought a 73 Dart 318 cable from RockAuto, ATP Part # Y156. Fits just fine.
PostPosted: Tue May 15, 2007 6:49 am
Hi all,
I realize this is an old thread, but my search of two days seems to be narrowing down. At least I have the right cable in sight.
I swapped the 1bbl manifold and carb out of my '63 convertible Valiant for a 2bbl setup and quickly learned that I had to go from a linkage throttle to a cable throttle.
I've read a few posts and even an article on this site about the process and realized what I was doing was part of a Super Six conversion.
Right now, I do not have the cable/pedal assembly and I'm trying to determine if, in fact, there is a direct swap set up for the pedal assembly that does not require any modification of the firewall or fabrication of a bracket.
If I'm understanding what I'm reading, then a cable/pedal assembly out of a v8 A body between '64 and '66 should do that?
Does anyone have a clear photo of the pedal assembly if this is the case?
Or, maybe someone can take a look at this item I found on ebay and let me know if I'm headed down the right track (or headed into trouble! :) )
ebay item#: 110124764852
I've had my Valiant in the garage for over 3 years now and my wife has never even had the chance to go for a ride in it! I have made a promise to myself that I was going to get my car on the road this summer because a '63 convertible Valiant sitting in the garage is such a waste on a sunny day! :D
Thanks very much!
Curtis
Golden, CO
P.S. The engine is a 225, by the way.
PostPosted: Fri May 25, 2007 10:23 pm
Hi all,
Yep...
Not on a '63. The first year cable-operated throttle provisions were present on the firewall was '64. Pre-'67 cable-throttle parts are pretty scarce, and you're looking at drilling holes whatever you use. Easiest path forward is to pick up a '67+ A-body accelerator pedal assembly and mount that up.
It'll bolt right to the floor, but you'll still have to drill the firewall. '67-up "hanging" accelerator pedals don't bolt to the floor at all.
That's a B-body setup. They can be made to work on A-bodies (need the B-body pedal) but...you guessed it...you have to drill the firewall!
You could probably grab a firewall-mounted hanging accelerator pedal assembly from just about anything with roughly similar footwell dimensions, it strikes me...
PostPosted: Sat May 26, 2007 4:33 pm
Thanks for the advice!
I did get a couple of B-body setups and they look more trouble than they are worth for sure.
I have a hanging setup from an A body, but it has this plastic grommet with a square peg. Should I use that? Or is there maybe a better one? If I'm not totally mistaken, I recall reading something somewhere about a hanging setup that didn't have the square peg grommet.
These are the times you just wish you had someone else's car to look at. :)
Thanks again!
Curtis
PostPosted: Sat May 26, 2007 8:42 pm
The plastic/square setup can be accommodated by simply using the matching throttle cable -- see earlier posts in this thread.
PostPosted: Mon Aug 06, 2007 11:11 am
Hello, i'd like to add a question in here since it seems to fit the subject.
Will the one barrel carb use the same accelerator cable as a two barrel carb in my 69 Charger? Autosupplyco.com has a calbe for my 69 dodge charger but it says its for a two barrel and i have a one barrel. my engine is out of a 70 Coronet.
thanks
Paul
in St. Paul
PostPosted: Mon Aug 06, 2007 11:33 am
There were no 2bbls installed on 225s in B-bodies in '69-'70, only 1bbls. The B-body cables are longer than the A-body cables. Autosupplyco.com doesn't come up for me, so I can't see what they're listing. What is the brand and p/n of what you're being shown?
PostPosted: Mon Aug 06, 2007 11:43 am
I typed in 69 Dodge Charger 225 and the cable that comes up is part number CA-8410. Description reads 2BBL; 3698839; Years1968-1969; Per Car Qty:1;
Another Charger owner told me that the cable needs to be 24" long. And it doesnt matter how many barrels the carb has.
Paul
PostPosted: Mon Aug 06, 2007 12:02 pm
No good, a CA-8410 isn't going to fit a '69. It's got the plastic square ferrule, and you need the metal round one.
Correct P/N for your cable is 2843 748, which is not cross-referenced in any book I have. Do you have a cable in the car at all right now? Can you measure its length?
PostPosted: Mon Aug 06, 2007 12:36 pm
Nope, the engine came without a cable. Is that part number a Mopar part number?
PostPosted: Mon Aug 06, 2007 12:43 pm
Yes, but probably been N/A for years.
If a 24" cable will work for you, then use ATP # Y155.
PostPosted: Mon Aug 06, 2007 1:01 pm
Thanks!
I owe you one.
PostPosted: Fri Aug 10, 2007 8:54 am
Accelerator cable came in yesterday and i figured out how to get it installed so thanks again SlantSixDan.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Semrush [Bot] and 1 guest
