It is currently Mon Dec 29, 2025 3:59 pm
PostPosted: Wed Aug 29, 2007 10:59 am
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
I need to get my truck through inspection, so I'm finally addressing my horn problem. I get a buzzing at the Painless Wiring replacement fusebox, but no honk.
So I try to make sure that the horn itself works by jumping it to the battery. It doesn't work, so I get a new horn.
This horn doesn't honk when attached directly to the battery either. How come? Do I need a relay? I thought that there was a relay in the Painless fusebox--do I need another one?
Thanks,
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
PostPosted: Wed Aug 29, 2007 11:53 am
Make sure the horn is properly grounded.
Most US horns have a grounded case to complete the circuit; many foriegn horns are floating and one of the 2 pins must be grounded for them to work. I've seen brand new universal replacements horns from the same vendor (F-something) with identical model numbers on the shelf with with some of one kind and some of the other.
PostPosted: Wed Aug 29, 2007 1:45 pm
Their name is ironic, given the degree and frequency of the pain caused by "painless" wiring's stuff. :-(
If you're getting a buzzing at the fusebox, it probably means your horn relay (installed there) is faulty.
PostPosted: Wed Aug 29, 2007 5:29 pm
Thanks for the replies, guys. I'll check the grounding of the horn.
Anyone have a part number for a nice generic horn relay?
Joe
Joe Hoppe
PostPosted: Wed Aug 29, 2007 7:02 pm
If Painless Wiring are still using GM-style fuseboxes, the relay you need is probably something like a Standard HR151 is probably what's called for:
Users browsing this forum: Ahrefs [Bot] and 1 guest
