It is currently Fri Jan 10, 2025 10:23 pm
 Post subject: Slant 6 weight
PostPosted: Wed Aug 29, 2007 4:33 pm
Anyone know the approximate weight of a slant-6? I just purchased a 225 and need to purchase an engine stand.
1987 Dodge D150 225 Slant-6 w/4-spd (A833OD)
PostPosted: Wed Aug 29, 2007 4:48 pm
It's not the weight that's the big concern, but the length of the engine and the center of gravity. I had a slant take a dive because the engine stand was too tall and narrow. Since it appears to me you can't buy anything other than a Chinese engine stand you might as well get one of the better ones. I have this: http://www.harborfreight.com/cpi/ctaf/d ... umber=4420
Very stable. You can spend less, but it's not that much money in the grand scheme. Check Craigslist too. You may find a good stand cheap or at least pay less for a cheapie.
PostPosted: Wed Aug 29, 2007 4:53 pm
I can't vouch for the accuracy of this list but according to it, the weight of a fully dressed slant 6 is 525 lb.
http://www.mopar1.us/engineweight.html
I believe that I read somewhere else that it was around 500 lb.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Wed Aug 29, 2007 5:18 pm
Thanks, Guys. The tip-over issue is a good thing to consider.
PostPosted: Wed Aug 29, 2007 5:47 pm
With manifolds and everything 525 is prolly a good number.
Make sure to get a two legged base. The "T" bases with one leg up the middle like to fall over when you push them around. :cry:
PostPosted: Thu Aug 30, 2007 5:26 am
I have two if them with a T base. I always take extra care when moving them around. I usually try to pull them by the front of the engine so that I can help to stabilize the weight. I'll be very happy when I can get the block off the stand in into the car.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 9 guests
