It is currently Sat Jun 20, 2026 7:56 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Fri Sep 07, 2007 8:05 am
think about it this way forget about the cam for a second. if you tighten the rocker adjustment nut it will open the valve more right? now about the cam if you don't change the amount the cam lifts and you need to adjust the rockers to compensate the cam re-grind then you end up with more lift.
PostPosted: Fri Sep 07, 2007 1:21 pm
:D Ok that is it. I got it now. It took a while to gel and a couple more posts :)
That is really neat.
Thanks guys:)
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
-67 Dart /6 4bbl, Leaning Tower of Power!!!
