It is currently Mon Jun 15, 2026 11:52 pm
 Post subject: pulling a 225
PostPosted: Thu Sep 13, 2007 5:07 pm
alright preety stupid question but i don't want to do even this the wrong way... what is the best and safest way to pull out a 225...where do i hook up and what do i use...chain or straps...and if your thinking man this guy must be wet around the ears...yeah i am when it comes to my dart...mopar guys are a breed thats not as strong as it used to be...least where i come from...can't get any of these old timers to talk to me...for free...thanks for the help
PostPosted: Thu Sep 13, 2007 5:09 pm
I use a short chain and a six pack of red ale.
PostPosted: Thu Sep 13, 2007 5:40 pm
Fisher,
I think you might like to get a load leveler. You will find the slant shifts around a bit and being able to level it has really helped me. Plus on the putting back in, you can tilit it backward enough to keep on a tranny and level it out as you get it deepen in the compartment. Levelers cost about $20 at harbor Freight. I think cherrypicker from the same store is a great tool to have too at a $150. I have sure used a chain in a tree a lot too! With that technology a leveler would have been bvery useful, too.
rock
'64 d100
PostPosted: Fri Sep 14, 2007 12:26 am
You may note that there are 2 bolt holes in the top of the head between
the intake/exhaust and valve cover, one each end of the head,
right on top........
There just for what your planning to do, pull the engine.....
use those bolt holes and the engine will balance pretty well
no mater how you go about pulling it.....
In manule cars I like to drop the trans and bell off before the pull....
On pre-69 D/W trucks drop the trans, flywheel and pull engine with bell attached
and on the manule \6 trucks there are bolts behind the flywheel you
need to remove the bell, much easier when engine is out
and install is much easyier when bell is attached to engine.....
Auto trans, drop or brace trans in place, pull engine
http://imageevent.com/jeffc
62 D100 225 3sp lwb
64 D100 A318 727pb custom lwb
66 D100 A318 4sp lwb
68 D100 B383 727 swb
65 Belveder A318 727 4d
65 Dart GT LA273 2bbl 904
73 Scamp 225 2bbl 4spOD
Old iron or no iron
 Post subject: Holes on top?
PostPosted: Fri Sep 14, 2007 2:38 pm
I went out and looked at nine today just to see these holes. Maybe I'm looking in the wrong place, but all I saw was one hole centered. It's the one to the left of the two front valve cover bolts in this pic.
If that's not what we're talking about, could one of you guys please post a pic or give me a better description of where these two holes are that I can't seem to find?
I'm surprised as a newbie that there is not an article on pulling the venerable /6!
Frank
PostPosted: Fri Sep 14, 2007 3:14 pm
6 Pack Dart
Looks very dirty clean between intake and exhaust on #5 cyl and above #1 exhaust behind thermostat housing
PostPosted: Fri Sep 14, 2007 3:18 pm
6 Pack Dart
My bad no hole on older head behind thermostat housing
 Post subject: Older head?
PostPosted: Fri Sep 14, 2007 3:21 pm
My '74 is an "older" 225?
Frank
 Post subject: Okay, I get it now
PostPosted: Fri Sep 14, 2007 3:26 pm
My auto choke heater modulator bracket is bolted to the rear hole. I don't have a front hole, just a middle one.
Thanks for the help guys!
Frank
 Post subject: i pulled it!!!
PostPosted: Fri Sep 14, 2007 5:48 pm
thanks for the help guys the bolt holes were rite where you said and i got that cherry picker swing worked great no bull took like 45min ripped it out clean....
