It is currently Mon Dec 02, 2024 11:12 am
 Post subject: Engine build
PostPosted: Wed Oct 31, 2007 10:54 pm
Hi Guys - I have decided to rebuild a truck engine from the ground up.
The Idea is to use the engine as a development mule for Manifolds I am playing around with
I used Dyno 2000 to run a lot of simulations on witch route I should follow.
At this stage things looks like this
9.8 CR
Standard Back cut valves, pocket porting, blending 5 angle valve job
OR MP 1.7/1.44 valves, with the same
Cam
.450 lift, 254 254 Duration 108 centreline
Port matched to a experimental Chrysler RSA 4 BBL Manifold with turned carb and plenum divider
OR Chrysler RSA long ram tube manifold with 2 X 36DCD7 Weber
Will try like crazy to have a dual plane like setup on the engine
6-2-1 Headers - ceramic coated inside and out - 2 1/2 inch to the back
The whole rotating assembly balanced and blue printed
Ignition
Recurved Chrysler electronic Dizzy, MSD Blaster 3 8.8MM Accell wires
HEI conversion OR MSD 6A
The whole idea is a High torque and a wide power band
Torque curve, according to the sim is very flat from 2000RPM to 3500RPM with 285 Ft/lb at 2500 to 3000 rpm dropping to 278 at 3500 oh yes- 282 available at 2000 :D :D
Peak HP 241 at 5500
The whole package will end up in my 1968 FB Barracuda in the end
SO
Opinions anybody - the running, 20000 mile truck block will be dropped of middle November as a gift from a buddy of mine
This engine is still in the planning stage as far as head mods is concerned
The rest will stay as close to the sim as possible
I entered the std 225 /6 info into this program and it kicked out a 8 hp more conservative output 140 instead of 148 - pretty acurate
One thing is clear if ever there was a asthmatic cylinder head, it is the one on the 225!
Very restrictive in every way - especially the exhaust system and valves.
The biggest output change is a good set of headers, then head massaging
Unfortunately it does not include ignition changes but still - up rated ignition will only improve matters
Ta
:twisted: :twisted: :twisted: there is going to be some shocked hot hatch drivers !
PostPosted: Thu Nov 01, 2007 3:15 pm
Not to far off from what I built. I did port the head but stayed with the stock valves for now. I have a very wide torque band for some very good punch!
I shock a few new Mustang GT's now and then. :D
PostPosted: Thu Nov 01, 2007 9:31 pm
Hi
I had a look in that Mopar Enigine Bible - and it is said - backcut thy own valves and thee shall have a fruitfull gain of 30 cfm.....
And it is way cheaper than over size
I am sorely tempted by a dual exhaust, but the 6-2-1 setup gives more torque
PostPosted: Fri Nov 02, 2007 9:16 am
That is true......
It would be nice if someone made available new long headers with only three tubes connected for good torque. The Clifford shorties just don't do much for torque.
PostPosted: Fri Nov 02, 2007 10:54 am
will give you feedback once my set is made up - the first thing the guys at TNT exhausts said - looks like your engine is falling out :evil:
THEN he said - we have lots of space for long tube headers
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
