It is currently Fri Oct 23, 2026 7:46 pm
 Post subject: Dart Lite 225 Block
PostPosted: Fri Aug 16, 2002 2:20 pm
OK gang, big problem or no problem. I went shopping today for the elusive "BH" block for my project. What I did find was a Dart Lite 225. These were only made in 75 and 76, "I think". I'm 95% sure this isn't a cast crank engine. The cast cranks came out in 1977, right? It has the extra ribs that Doc refers to on the BH block, but I have not found the casting number on the block.
I have my steel crank and 1mm oversize (+0.085") pistons "ready to go". Am I in for an unpleasant surprise with this block?
Thanks in advance for your help.
Gilly
tlg225ccr@aol.com
PostPosted: Fri Aug 16, 2002 3:20 pm
: OK gang, big problem or no problem. I went
: shopping today for the elusive
: "BH" block for my project. What I
: did find was a Dart Lite 225. These were
: only made in 75 and 76, "I think".
: I'm 95% sure this isn't a cast crank engine.
: The cast cranks came out in 1977, right? It
: has the extra ribs that Doc refers to on the
: BH block, but I have not found the casting
: number on the block.
Does that block look like this one?
It could be one of the last forged crank units, look for the tapered water pump rib. (thats not a 100% indicator but it's another clue)
Link to engine ID messages
PostPosted: Fri Aug 16, 2002 4:03 pm
: Does that block look like this one?
YUP, YUP. That's EXACTLY what it looks like.
The first numer is 030-10 and the second in the little oval is 2695? ( I think). Now for the dumb question. The rib does taper front-to-rear, but doesn't get "thicker" as it gets close to the
Thanks for the help.
Gilly
tlg225ccr@aol.com
 Post subject: Dart Lite OH YEAH !
PostPosted: Fri Aug 16, 2002 5:28 pm
You wouldn't have a pic of that Dart lite would ?
Very rare car now... I would be interested in a scale pic of the emblem.
PostPosted: Fri Aug 16, 2002 5:34 pm
: YUP, YUP. That's EXACTLY what it looks like.
:The first number is 030-10 and the second in the
: little oval is 2695? ( I think). Now for the
: dumb question. The rib does taper
: front-to-rear, but doesn't get
: "thicker" as it gets close to the
: Thanks for the help.
: Gilly
Thick at the block and thin as you move out to the end of the water pump "ear". (mounting flange)
 Post subject: Block ID Cont'd
PostPosted: Sat Aug 17, 2002 5:30 am
: Thick at the block and thin as you move out to
: the end of the water pump "ear".
I was afraid of that. On this block, no taper. I'm holding out until I pull the crank.
As for the embelem, the car is in Petersburg VA. I'll take a camera the next time I go.
My continued researh turned up info in the "new" Mopar Performance book stating that the blocks went to a "thin wall" design in 1974. Limits, "per the book" are:
1960-1973 0.060" Max
1974-1984 0.030" Max (wonder if this is what the "30" on the side of the block means?)
Of couse, I'm SURE everyone here always follows Daimler/Chrysler's recommendations exactly LOL :). I have a set of +1mm (+0.085") KB 268's ready to go. Have any of you punched out a later model block this much?
Gilly
tlg225ccr@aol.com
 Post subject: Re: Block ID Cont'd
PostPosted: Sat Aug 17, 2002 7:23 am
As far as I know, most any Slant block will go +.100". I know some brave souls who go +.130".
slantzilla@excite.com
PostPosted: Sat Aug 17, 2002 9:39 am
: I was afraid of that. On this block, no taper.
: I'm holding out until I pull the crank.
You just have to get a look at the crank, there are reports of the first "thin rib" blocks having forged cranks. (75-76 years)
PostPosted: Sun Aug 18, 2002 8:27 am
: As far as I know, most any Slant block will go
: +.100". I know some brave souls who go
: +.130".
Do you call it brave or something else ? I went to .130" over but I also filled the cylinder block with cement to with-in 1 1/2" from the top.
So far so good ?
damuel@kalama.com
 Post subject: That's my boy!
PostPosted: Mon Aug 19, 2002 3:54 pm
That's my son and my block. It is a forged crank block and it's done. Runs real strong.
MAndreas@aol.com
 Post subject: Re: That's my boy!
PostPosted: Mon Aug 19, 2002 5:22 pm
: That's my son and my block. It is a forged
: crank block and it's done. Runs real strong.
Hope you don't mind me "recycling" your PIC.
With any luck, we will figure out which "thin rib" blocks have the forged cranks, I'm not sure how many years are like that.
Users browsing this forum: No registered users and 26 guests
