It is currently Sun Feb 23, 2025 5:54 pm
 Post subject: roller rockers?
PostPosted: Mon Nov 19, 2007 8:17 pm
any word on dates for that roller rockers deal? I'd go with brass bushings at the fulcrum and roller tips, according to what Lou hass been taling with the manufacturer. Dates? prospects? ratios?
Juan Ignacio Caino
PostPosted: Mon Nov 19, 2007 9:43 pm
Juan
I think that may have died due to oiling issues.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Nov 20, 2007 2:28 am
Frank I seem to recall that Lou Madsen (dart 270) talked to the guy and was satisfied with the answers??? Lou, can you chime in?
Juan Ignacio Caino
PostPosted: Wed Nov 21, 2007 8:20 pm
would a full roller bearing take care of the oiling problem? The pop's and I seem to think that might take care of the problem. Also if anyone has an already built set I would be interested in the overall length of the rocker. Thanks
PostPosted: Thu Nov 22, 2007 6:08 am
Oiling the roller tip and the valve guide, with those locations being "up-hill" is the problem.
PostPosted: Thu Nov 22, 2007 6:44 am
In this case, a tube of dribber oil for all 12 tips directly.
Cheers, Wizard
PostPosted: Thu Nov 22, 2007 5:08 pm
doc are those cox bros' ?
Juan Ignacio Caino
PostPosted: Thu Nov 22, 2007 9:58 pm
Rocker Arm Specialist (RAS) made this set.
PostPosted: Sun Nov 25, 2007 6:11 pm
I spoke with T&D and was satisfied that their design should work fine.
Doc's pic is of the early RAS units, I believe. I was just at Seymour's place and he had the latest generation RAS set, which had grooves on the bushings to allow better oiling. Looked to me like those could work fine. The ones I tried were early RAS units with no grooves and did not oil right. I need to check the ones I have to see if cutting grooves would solve their problem.
At this point, I am still interested in a T&D set, if it happens.
Users browsing this forum: Bing [Bot], Semrush [Bot] and 49 guests
