It is currently Tue Nov 26, 2024 10:43 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Mon Jan 29, 2007 7:05 pm
Well, looks like the valve wasn't the problem. Pulled it out, cleaned it up (although, keep in mind it was brand new) and reinstalled it along with the pretty pink spring, pulled the coil wire, and cranked the engine over.
Zero. Zilch. Not even a quiver from the pointer.
So, at this point, I pull the oil pump (oh, joy), and pray it's the gear on the pump? Is there any chance it's the gear on the cam, or does that drive the distributor?
I DON'T look forward to pulling the oil pump with the engine in the car...
vm
PostPosted: Mon Jan 29, 2007 9:23 pm
A pink spring?? Funny......I just looked at mine(Melling) and it's purple!! It almost feels "weaker" than my old spring...! :shock:
Is it normal to have different colors???
BBBanjo
PostPosted: Mon Jan 29, 2007 9:47 pm
Different spring tensions are indicated by different paint colours, but there's no consistency any more, so you can't say the purple spring is stiffer than the red or green or whatever.
PostPosted: Tue Jan 30, 2007 4:14 am
So, I guess there's no way of knowing how much damage could've been caused by the lack of oil pressure short of pulling and disassembling the engine, right?
Any particular brand of pump I should look for (or avoid)? The one that failed was a Melling.
It'll be just my luck to replace the oil pump, only to spin another bearing or throw a rod a week later.
Thanks, guys.
vm
PostPosted: Tue Jan 30, 2007 4:29 am
You can drop the pan and pull a couple of rod and main caps for inspection. you could even replace all the bearings from below as long as the crank journals are undamaged. Also pull the distributor to make it easier to inspect the cam gear for chipped and broken teeth.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Thu Nov 22, 2007 10:23 am
DD,
Why is the cut off wheel in the picture? What is the purpose of cutting the slots in the piston. Where do you put the washer/shims to increase the pressure?
PostPosted: Thu Nov 22, 2007 10:35 am
I don't know why the cutoff wheel's present in that photo, but the slots are there in the valve shuttle from the factory. The ¼" nut, stack of washers, or other shims to increase the regulated oil pressure go between the spring and the screw-on cap.
PostPosted: Thu Nov 22, 2007 10:06 pm
The cut-off wheel is used to open-up and deburr the slots in the valve.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 14 guests
