It is currently Wed Jun 24, 2026 4:59 pm
 Post subject: Coolant Hoses
PostPosted: Fri Nov 30, 2007 9:38 am
My most recent drive from New Orleans to Houston was lengthened somewhat when I blew the small water hose (~3 in) that connects the water pump to the front of the head. I had been using some kind of black rubber hose that I'd gotten from the parts store a few years back, and it appears to have started to deteriorate. To make a long story short, I had enough slack in one of the heater core feed lines to cut a replacement piece. Thank God it had rained heavily the night before, because I only had 1 gallon of water in my trunk. With a radiator full of crystal-clear Louisiana ditch water, I made my way down the road.
My question to you gentlemen is this: what type of hose do you recommend for coolant lines? I want something with longevity that won't fall apart after 3 years. Money is not a factor, as an incident like this could easily have meant a very expensive tow. Also, is there a company that makes pre-made hoses for the Slant?
T.I.-freakin-A.
Escape Velocity Racing
PostPosted: Fri Nov 30, 2007 9:53 am
for that hose in particular I like to use sillycone (silicone) cuz it is hard to fish a new hose in their when they blow out. when i get a new slant one of the first things I do is to replace the water pump and switch to sillycone hose their.
PostPosted: Fri Nov 30, 2007 9:54 am
Heavy-duty silicone heater hose with double-wrap band clamps.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 5 guests
