It is currently Sun Jun 21, 2026 10:43 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
 Post subject: rings
PostPosted: Tue Dec 04, 2007 6:41 pm
you should do as lou suggested and go with .020/.022, i set mine at .024 because with the heat that high compression creates, if the gap is to close the ends will hit when they exspand and pin will be pulled out of the piston when it sticks in the bore :wink:
PostPosted: Wed Dec 05, 2007 6:39 am
I have mine at 0.022" for an 11:1 motor, so hopefully that's enough!
PostPosted: Wed Dec 05, 2007 3:17 pm
Some pistons call for different gaps. Hypertec come to mind.
PostPosted: Wed Dec 05, 2007 3:40 pm
the position company set them at the .003 for a race application but I am building mine to drive almost daily I think I am going to Go will Lue and set them at .022 of may be .021. Thanks for the help god knows I need it
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Thu Dec 06, 2007 6:34 am
You really need a bigger gap for racing, not smaller. 0.020-0.022" should do fine.
