It is currently Fri May 01, 2026 10:03 pm
PostPosted: Fri Sep 13, 2002 10:30 am
Since my engine is stock, I don't need the extra strength or cost of a 8-3/4, so I'm going the 8-1/4 route in my '64 Valiant. That also makes it easier to get the big bolt pattern that I want.
To those that have done this swap, is there anything special that I should consider before doing it? Any special year I should look for? Are the U-joints larger on the 8-1/4?...or is it a bolt-up? What about brake hoses?
lancer_41@excite.com
PostPosted: Fri Sep 13, 2002 1:24 pm
: To those that have done this swap, is there
: anything special that I should consider
: before doing it? Any special year I should
: look for? Are the U-joints larger on the
: 8-1/4?...or is it a bolt-up? What about
: brake hoses?
It is a bolt up. You need the u-bolts and shock plates from the 8.25". The parking brake cables from the 7.25". The U-joints are the same. The driveshaft will need to be shorted.
klesteb@aoo.com
PostPosted: Fri Sep 13, 2002 3:31 pm
Where do you guys find all the A-body 8 1/4 housings? The only ones I've seen are in the 340-360 cars and they're hard to come by. I find the A-body 8 3/4 easier to find since they were used in a lot of 318 cars. Is there another A-body engine combo the 8 1/4 was used besides the 340-360?
ceh52@quik.com
PostPosted: Fri Sep 13, 2002 7:06 pm
: Where do you guys find all the A-body 8 1/4
: housings? The only ones I've seen are in the
: 340-360 cars and they're hard to come by. I
: find the A-body 8 3/4 easier to find since
: they were used in a lot of 318 cars. Is
: there another A-body engine combo the 8 1/4
: was used besides the 340-360?
I got my 8 1/4" axle assy from a '73 or '74 318 Duster with disk brakes.
fglmopar@aol.com
PostPosted: Sat Sep 14, 2002 6:40 am
Thanks Bud. I went looking for an 8 1/4 rear about two years ago. I checked 5 or 6 A-body disc brake 318 cars and they had 7 1/4 rears, so I quit looking. Now I know they are out there, the hunt will continue. I want it and the discs for my '68 V-100.
ceh52@quik.com
PostPosted: Sat Sep 14, 2002 8:06 am
: Thanks Bud. I went looking for an 8 1/4 rear
: about two years ago. I checked 5 or 6 A-body
: disc brake 318 cars and they had 7 1/4
: rears, so I quit looking. Now I know they
: are out there, the hunt will continue. I
: want it and the discs for my '68 V-100.
It's been over ten years ago, so my memory is a little fuzzy. It may have been a stick(3 spd floor shift) car.
fglmopar@aol.com
PostPosted: Mon Sep 16, 2002 7:52 am
: It's been over ten years ago, so my memory is a
: little fuzzy. It may have been a stick(3 spd
: floor shift) car.
I have a 73 Swinger parts car in the yard, 318, 904, disks and 8 1/4. I also have another 8 1/4 with 2.94 posi that came out of a 75 Duster 318, 904 combo.
Hot-Rod 6
dave.clement@motorola.com
