It is currently Sun Nov 22, 2026 10:13 pm
PostPosted: Sat Feb 09, 2008 11:23 am
I'm planning to buy a '66 slant from a guy in Seattle when I get back to the states, and before I install it into the car I'll be getting a rebuilding a late model, lockup 904. I'm told that the crank inset on early slants is smaller than on later models. Will this be easy to find an appropriate lockup converter for, given that early 904 were non lockup? I had been under the impression that it would be a simple job to mate a later 904 to an early engine. Perhaps not?
PostPosted: Sat Feb 09, 2008 12:13 pm
It's easy to mate a '68-up engine to a '67-down transmission, but harder to go the other direction. There is no appropriate lockup converter for this what you want to do. Non-lockup custom converters to do this job have been specially built, but I'm not even sure if a custom lockup converter can be made to fit the pre-'68 small-counterbore crank. It may be easiest just to machine the counterbore on the early crank so that it is 1/4" larger (I.D.) and go ahead and use an off-the-shelf lockup torque converter.
I take it you're going with a late-model trans to get the wide-ratio gearset? I did that...once. Didn't like it, not gonna do it again.
PostPosted: Sat Feb 09, 2008 1:57 pm
So I take it machining the counterbore on the crank is the only way to achieve this? I suppose I could have that done easily enough. I've honestly never pulled a crank before, but I suppose I have to start somewhere (and it'll be on an engine stand until I have a tranny ready to go anyway).
The wider ratio gearset isn't really a concern to me (though I would rather have closer ratio gears). I want the later model tranny so I can have the lockup function for long stretches of highway driving and for the economy aspect of it (it'll be mated to a Gear Vendors OD at some point in the future).
PostPosted: Sat Feb 09, 2008 3:16 pm
My setup involved the installation of an input shaft and some front pump parts from a '66-'67 trans into a '68-'77 non-lockup trans equipped with the '80+ wide-ratio gears. I didn't like the wide-ratio gears. I can understand wanting lockup — it can save you 5% or so on fuel — but just think through how you're going to go about it beforehand, and do the math to figure out your payback period on that and the (very costly) GV unit.
PostPosted: Sat Feb 09, 2008 4:33 pm
So seeing as how I'll be rebuilding a lockup 904 anyway, would my better option be to install an input shaft from an early 904 (if they're even interchangeable)?
Were there any lockup 904s with the close ratio gearset?
Man I'm starting to winder if I'd be better off trying to mate a four speed auto to my slant...
PostPosted: Sat Feb 09, 2008 4:56 pm
The answer to your question hinges on whether a small-nose, lockup torque converter can be built, or if you can machine the counterbore in your crankshaft, or swap in a '68-'76 crank. If the answer to any of these is "yes", then installing a lockup trans will be simple, though cost may vary depending on parts availability.
The 4-speed autos aren't as sturdy as the 3-speed units, but a properly-built one ought to hold up OK behind a slant-6. Floor, crossmember, and driveshaft mods will be needed. The (discontinued) AREngineering adaptor plate could be used to mount one of these to the slant, but you will still run into the very same torque converter/crank fitment problem.
It seems to me you could probably do a 5-speed manual swap for less than a GV over/underdrive...
 Post subject: I think...
PostPosted: Sat Feb 09, 2008 7:40 pm
Not too long back I think Charrlie S had posted that because of how the lockup is set up you can only get the lockup torque convertor in the large hub/snout... so you will be in for a late crank, turning the crank pocket on the 66 crank, or a crank kit for a 1968-1975 225...
 Post subject: Re: I think...
PostPosted: Sat Feb 09, 2008 8:05 pm
I didn't post that, but I would believe it. The best thing to do would be to call a converter builder, and ask. I have seen several people post, about machining the early crank to the late model hole size. I have to question if this can be done. There is a pilot to locate the flexplate. I don't know it this will be a problem or not. I will measure this tomorrow, and see what I think. Has anyone actually machined the hole in the early crank, and verify, that it works?
PostPosted: Sat Feb 09, 2008 8:35 pm
:wink:
Charrlie back in March 10, 2006... when another member had the same problem and I didn't have access to a lockup rebuild book...
here
It will not work, with a lock up converter. The pilot on the converter is hollow, to accomadate internal components. With the lock up converter the hole in the pilot is larger, and there is not enough wall thickness to reduce the outside diameter. The same situation holds true with a late 727 trans, the converter cannot get the smaller pilot.
You 'da man!
-D.idiot
PostPosted: Sun Feb 10, 2008 4:11 am
The four speed comment was just in jest. It'd be even less work to install a kit from classic5speedmopars.com (who I'm still waiting to hear back from on an A body, slant kit as I heard one of our members is letting them use his car as the guinea pig). If that ever comes to fruition, I'll go that route instead of the GV unit on a lockup 904. My next deployment will pay for either a GV unit or a 5-spd kit, depending on what's available at that point :twisted:
At this point I'll plan on pulling the crank and having it machined to accept the later model torque converter.
Now, here's another question: is there any difference in strength between early and late model crank shafts? I'm wondering if it would be better for me to get a late model crank, have it balanced and use that instead. Then while everytihng's apart I could balance the whole bottom end...
PostPosted: Sun Feb 10, 2008 5:43 am
:wink:
here
You 'da man!
-D.idiot
Hell that was 2 years ago. At my age I can't remember 2 days ago. :roll:
PostPosted: Sun Feb 10, 2008 5:54 am
I hear ya Charlie....its not what you know...its what you can remember at the time....
CRS
PostPosted: Sun Feb 10, 2008 6:37 am
double post
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Feb 10, 2008 6:38 am
That is certainly an option, perhaps the best option. I'm pretty sure the cranks are interchangable other than the tranny hookup as long as you don't try to use the cast crank from the late engines.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Feb 10, 2008 7:13 am
Yeah I'd much prefer to use a forged crank. What years started getting the cast crank, and what'd be a good course for me to find one (forged)?
