It is currently Sun May 31, 2026 2:11 am
PostPosted: Sat Feb 23, 2008 8:35 pm
This is an interesting new one on me. I thought brake lines absolutely needed to be made out of steel, but apparently a copper-nickel alloy is significantly superior and Volvo + others have been using it exclusively since the mid-1970s:
http://www.cunifer.com (scroll down to the bottom of the page for links to detailed papers)
PostPosted: Sun Feb 24, 2008 7:13 am
I wonder what the cost difference is. I'm strongly debating on replacing all my hard lines when I R&R the brakes on my Duster, and this sounds like a good idea.
On the subject of hard brake lines, What's the deal with the "coil" of hard lines that I usually see fairly close to the master cylinder? I see alot of people purposefully do that in their custom line installations and I've always wondered what the reasoning is.
PostPosted: Sun Feb 24, 2008 7:14 am
Isn't the coil to protect rubbing?
 Post subject: I always did it because
PostPosted: Sun Feb 24, 2008 8:29 am
Im too lazy to cut the tube to length, and the spiral solution looks fine. It also provides a good bit of springy slack to get the fitting started.
madam im adam
PostPosted: Sun Feb 24, 2008 8:38 am
As I understand it, the loops between master cylinder and metering block are to allow that line to move/flex with normal car vibration, without fatiguing the metal over time.
PostPosted: Sun Feb 24, 2008 4:17 pm
Also, I usually see it with body on frame construction where the master is connected to the body and the brake lines to the frame.... Allows some movement between the two.
