It is currently Wed May 20, 2026 2:09 am
PostPosted: Mon Apr 07, 2008 1:20 pm
I bought a 77 Aspen donor car with sl6 and 833 OD trans to go into an 80 Volare with sl6 and automatic. In doing my research I discovered that when doing a auto to std conversion on a V8 the cranks that came with autos were not machined to accept the input shaft bushing/bearing.
Is this an issue on the slant six cranks?
Thanks,
Scott
Scott
1956 Dodge Custom Royal Lancer
1980 Road Runner (Dont call it a Volare!)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette Stingray
PostPosted: Mon Apr 07, 2008 3:31 pm
all the slantsix`s i have come accross are machined for the pilot bushing, i used all the parts of a 76 aspen to go in my 75 duster no problems :)
 Post subject: Nope...
PostPosted: Mon Apr 07, 2008 5:39 pm
It's more hit and miss for the late cast cranks... My '79 block was not and I had to use the NAPA problem solver bushing with some loctite for it... so far all the forged cranks I have (pre-76ish) have either been drilled or already had the bushing in it...
PostPosted: Tue Apr 08, 2008 11:30 am
D idiot, what type of bushing was the napa one ,and how does it work
PostPosted: Tue Apr 08, 2008 12:42 pm
You can also use a roller pilot bushing from a V-6 or V-8 Dakota. It will drive into the crank register for the converter. :D
 Post subject: Your two choices...
PostPosted: Tue Apr 08, 2008 1:27 pm
Balkamp 615-1033 is a stockish style oilite pilot bushing with and undersized outer diameter... for those cranks that have the hole but it's not finished/drilled to the correct diameter... you coat the bushing with HD loctite and insert into the crank, leave until the loctite settles (about 20 minutes+), then insert a small amount of grease per SOP and install your clutch...
Option two is a bit better, as big D has said order mopar part number: 53009180AB for a Dakota V-6 or V-8 is takes up the pocket in the crank...
good luck,
-D.idiot
PostPosted: Wed Jun 11, 2008 10:19 pm
Will I need this Dakota bushing to mate an auto /6 to my 3-on-the-tree tranny? It's a 1965 tranny and a 1972 /6.
 Post subject: Maybe
PostPosted: Thu Jun 12, 2008 5:41 am
You might, check the back of the crank and see if it has a finished hole or a bushing in it already...
PostPosted: Thu Nov 06, 2008 9:44 pm
Turns out the '65 motor had a bushing which we were able to remove with a puller and put into the '72 motor. The end of the crank on the '72 motor was bigger, so I had to have the center hole of the flywheel machined larger....then all was well and the motor went in. thanks!
Users browsing this forum: No registered users and 21 guests
