It is currently Wed May 27, 2026 3:22 pm
PostPosted: Tue Aug 12, 2008 9:21 pm
its basically jibberish to me, found an old marine camshaft, looked up the numbers and this is what it told me
Durations at .050 lift
int 198*
ex 203*
Cam Lift
int .270
ex .276
Lobe centers
in 106*
ex 112*
I don't quite understand these figures, usually people speak in degrees like, "Mine is a 270*" or what ever, are these different numbers at different specs? ha ha, I am confused, would appreciate all help!
thanx
morgan
PostPosted: Tue Aug 12, 2008 11:01 pm
Looks like the '71 and up cam which was used earlier as the marine cam. It's about 244° advertised duration and is ground 3° advanced with 109° lobe separation. Multiply the cam lift by 1.5 to get the gross valve lift. Take away the lash setting from that to get the net valve lift.
