It is currently Mon Oct 12, 2026 3:06 am
 Post subject: Valve lash theory
PostPosted: Thu Aug 21, 2008 10:47 am
Considering I am working on a reasonably healthy 49K slant engine circa '72....can I assume that the cylinders that will benefit the MOST from a valve lash are the cylinders that affect the smoothness of idle quality the LEAST when pulling sparkplug wires. just to clarify, some cylinders will cause a major shake/skip when spark is removed (I would consider them major players) but some are barely noticeable when removing spark. Does this theory fly?? Thanks, nico
PostPosted: Thu Aug 21, 2008 10:52 am
The theory is sound only if those cylinder not pulling their own weight are misfiring due to their valves being held open from a deficit of lash.
PostPosted: Thu Aug 21, 2008 11:09 am
Josh is right, but it doesn't bear worrying about which cylinders will benefit more or less than which other cylinders from correct valve lash. Just adjust all the valves correctly — here's the valve adjustment procedure.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 49 guests
