It is currently Wed Nov 11, 2026 4:38 pm
 Post subject: blinker issues
PostPosted: Wed Nov 12, 2008 12:22 pm
I currently have no turn signals working in my car. 73 scamp. So I figure the turn signal relay is messed up. However, when I put on the emergency flashers, the left blinker starts working. I am totally confused. I think its two separate problems. Any thoughts?
What's that fuzzy blue thing being hurled this way?
::stick::
BOOSH!!!
PostPosted: Wed Nov 12, 2008 12:32 pm
You probably need a replacement turn signal switch.
 Post subject: Blinker Fluid
PostPosted: Wed Nov 12, 2008 12:35 pm
You might need some blinker fluid:
http://kalecoauto.com/index.php?main_pa ... ducts_id=6
PostPosted: Wed Nov 12, 2008 12:57 pm
Have you tried and observed what happens when you move the turn signal switch up or down with the flashers on? If nothing happens, then I would go with Dan's suggestion.
~THOR~
PostPosted: Wed Nov 12, 2008 4:06 pm
there are two flashers in your car; one for emergency four-way, the other for turn signal. their location varies; for mine the turn signal flasher is clipped to the outside of the glovebox liner and the four-way is clipped to the steering column support. it is a good idea to replace any bimetallic flasher (with a tin or light blue plastic casing) with the HD-12 electronic flasher.
begin by replacing the turn signal flasher. next inspect your turn signal bulbs. ensure the filaments are intact and the sockets are clean, use a battery brush to remove scale and coat the new bulb base with dielectric grease. if this still does not solve the problem, you need to get out your multimeter and check the continuity of the switch as well as +12V present at the switch feed wiring and the flasher. since the switch is the most difficult and expensive item to replace in the circuit, i would investigate all other possibilities first.
PostPosted: Wed Nov 12, 2008 6:17 pm
Ok cool. Thanks. BTW, the blinker fluid is on the way. I also wanted a Heisenberg compensator, but its on backorder.
::stick::
BOOSH!!!
PostPosted: Thu Nov 13, 2008 12:26 am
Don't forget to check the muffler bearing at the same time you check the blinker fluid. They go hand in hand don't you know.....
PostPosted: Thu Nov 13, 2008 3:48 am
I hope you got the purple synthetic blinker fluid.
PostPosted: Thu Nov 13, 2008 4:58 pm
I got the K-mart Blue light special blinker fluid. Almost as good as the purple and half the price. I also got a flux capacitor on the cheap as well.
::stick::
BOOSH!!!
PostPosted: Thu Nov 13, 2008 9:23 pm
I had a bulb that wouldn't blink, so I got a new one, and BLINK!
You got a pretty sweet deal there! Im supposedly getting a Mr.Fusion, but its on back order as well. :lol:
'74 Duster 225 Super Six w/904
14" Cragar SS wheels
PostPosted: Fri Nov 14, 2008 3:48 am
Just add a little transmission fluid to the blue light stuff, not light blue that's for four way's, volah!, home brew purple...
 Post subject: return
PostPosted: Tue Nov 18, 2008 5:07 pm
often on 73 models the piston return spring goes bad too . :shock:
63 valiant v200 Wagon 9.5, Schneider cam, E.I. 22 mpg all day
PostPosted: Wed Nov 19, 2008 10:16 am
Car Model: 1968 Plymouth Valiant 100
I may be off here but I know I posted a similar question. My blinkers worked fine but when I would turn on my flashers they wouldn't work unless I turned my left or right blinker on. I thought it had to do with a switch but after I was done rewiring my car everything worked as it should. Like I said, I may be off or completely wrong or both.
By the way, was the flux capacitor from napa? Because the others normally always send you back to the future :shock: -Dan
PostPosted: Wed Nov 19, 2008 2:23 pm
naw i got the flux capacitor from ACME
::stick::
BOOSH!!!
PostPosted: Fri Nov 21, 2008 7:33 am
as long as your flux capacitor keeps on fluxing!
