It is currently Mon Mar 03, 2025 9:57 am
 Post subject: Electronic Pickup plate
PostPosted: Fri Feb 21, 2003 4:40 pm
Is this the only part that differentiates a stock distributor from an electronic? I found one on eBay and if all I have to do is swap it into the stock distributor, I'll take it.
 Post subject: Don't think so!!
PostPosted: Fri Feb 21, 2003 5:00 pm
6 Pack Dart
It would be nice BUT, don't think you ever looked at an electronic distributor. Go to the library and look in the mopar section of a motors , Chilton or one of the rest of the auto repair books.
PostPosted: Fri Feb 21, 2003 8:31 pm
I would have looked, but I don't have the Haynes at my place :?
But I'll take that as a no and keep watching that NOS electronic distributor that's up too...
PostPosted: Fri Feb 21, 2003 10:58 pm
6 Pack Dart
That NOS distributor looks good, I got my distributor at wrecking yard, paid $35 for all you can pack out. So got 2 or 3 plus a lot of other things.
The electronic has a control box it will have 4 or 5 wires on a plug that is held in place with a screw. Beter yet look in the articles section for ignition up grades should answer a lot of you questions before you have to ask them.
Also the advance rates are controled by 2 springs under the plate, and the total advance is controled by the length of the two slots in the plate there should be a number stamped on the plate if it is 15 the total advance is 30 degrees.
Get back to me if you have more questions.
 Post subject: more distributor info
PostPosted: Sat Feb 22, 2003 6:12 pm
6 Pack Dart
check out Dougs page
http://www.dutra.org/doug/draft-webpage ... ibutor.htm
this should help you out
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Semrush [Bot] and 32 guests
