It is currently Thu Feb 27, 2025 2:42 pm
PostPosted: Sun Feb 23, 2003 5:22 pm
exactly how do you do this and still make it streetable? i want to run lower 14 high 13's, what engine block year to use? can a hyper pack fit with power brakes? i would also know how to set up for nos. and how to swap the 7 1/4 to 8 1/4? what gears to run?
thanks alot
PostPosted: Mon Feb 24, 2003 6:57 am
forced induction and a good 100shot of NOS :twisted:
Forget the flowmasters...here come the good ol' GLASSPACKS!!!
PostPosted: Mon Feb 24, 2003 8:55 am
It is best to think about this in terms of power and weight needed to hit a stated ET.
To get a 3000 lb car to go 14.99 will take about 175 HP at the wheels.
To run a 13.99 in the same 3000 lb car takes 225 HP.
Do you know your car's weight? How light can you get it?
The other thing to understand is that good dragstrip ETs are done from a standing start, that means low rearend gears and high converter stall speeds. These changes make for good dragstrip or "stoplight fun" but this set-up sucks on the open highway.
PostPosted: Mon Feb 24, 2003 12:35 pm
my car is a 1974 dodge swinger, i dont know how much it weights, would i need forged pistons to run 100 shot of nos? i can get free machine work so if this helps at all, and also i will have about 2500?
thanks
PostPosted: Mon Feb 24, 2003 2:00 pm
Free machine work will help but be sure it is done correctly.
I would do a basic performance build-up using the Enginetech cast pistons, .060 oversize. Add a balance job and a performance cam and the short block is done. There is a rundown on parts in the HRM article.
http://www.slantsix.org/articles/hrm-sl ... ckness.htm
Spend all you time and money on cylinder head work as well as a good intake and a set of headers.
PostPosted: Mon Feb 24, 2003 6:06 pm
ok so exactly what should i do with the head i want to be fast and good i dont care if i have to run preminum gas, will the hyper pack intake fit my car with power brakes? i al a little bit uneasy ordering from clifford beacuse of waht i have herd from other people.
PostPosted: Fri Feb 28, 2003 4:03 pm
so does a hyper pak fit in an a-body with power brakes? I'm curious too.
73' Duster 225
<img src="http://longrod.moparpages.com/enginedone.JPG" width=200>
PostPosted: Fri Feb 28, 2003 6:00 pm
I have never used one on a car with a power brake booster.
Is your booster the long skinny one or the short fat type?
(I do not know how else to discribe the two types I see on A Bodies)
:wink: DD
PostPosted: Fri Feb 28, 2003 6:20 pm
short and fat :)
73' Duster 225
 Post subject: SE or not SE?
PostPosted: Fri Feb 28, 2003 9:59 pm
74 Dodge Dart Swinger is 3030 or 3055 lbs. depending on 2 or 4 door model for the 'shipping weight'. If it's an SE (Special Edition...aka luxo model) it weighs up to 3700 lbs....
Users browsing this forum: Ahrefs [Bot] and 19 guests
