It is currently Tue May 19, 2026 11:41 pm
PostPosted: Tue Dec 09, 2008 9:19 am
The car has a 3 speed on the column and I was wondering if anyone knew what tranny I have?
72 Swinger Special Originally a 3 speed 198/6 car now has a 225 with the 3 speed
72 B200 Shorty Van 225 /6
4 other Fullsize Mopars from 65-73
PostPosted: Tue Dec 09, 2008 10:13 am
Is it a manual column shift with a clutch? If so, the trans is most likely a A-903 or a A-745, non-syncrow 1st 3-speed.
If it is a column shift automatic, 99% of the time, it will be a A-904
 Post subject: Column shifted manual
PostPosted: Tue Dec 09, 2008 11:11 am
Its a column shifted Manual Transmission(With a clutch). How can I tell the difference between an A-903 and an A-745?
PostPosted: Tue Dec 09, 2008 11:51 am
The 903 has a flat cover on the top, the 745 has a small upward "bump" in the front of the cover.
To be honest, both these gearboxes are weak and have a non-syncronized first gear. Combine that with the "long and sloppy" column shifter and these can be a "chore" to drive.
A great improvement would be to swap to an 833 4-speed or retrofit a newer 5-speed into the vehicle.
PostPosted: Wed Dec 10, 2008 6:35 am
I originally bought a swap meet shifter to convert my 903 to the floor.
There is NO mounting points on that tranny to do that!!
If I can ever get back to work the 833OD hanging in there will be nice to drive.
