It is currently Tue May 19, 2026 2:27 pm
PostPosted: Sat Jan 10, 2009 12:30 am
Looks like a piece of angle iron will do the trick..with the right dimensions, that would be a snap to make. (hint hint, wink wink, nudge nudge) :wink:
PostPosted: Sat Jan 10, 2009 12:33 am
Got one myself that I made.Mid70s chilton man for Dodge vans gives details and measurments.The factory van plate bolts to 3 intake/ext studs and has a strap from plate down to threaded hole by pan. I've got a drawing with sizes around here somewhere would post but my photobucket wont work,it looks almost like Ron's.
please give use that info please. i need more crap mounted to my engine :twisted:
PostPosted: Sat Jan 10, 2009 8:26 am
In action with other van related "tool".
PostPosted: Sat Jan 10, 2009 10:35 am
I should add that my plate is van specific for shop in/out not factory for cars/pickups. It also needed to be moved ahead one stud worth for proper balance.I'll let Ron post sizes for his as most here are not working on vans like myself,you can see the lifting holes are off set abit from his.
PostPosted: Sat Jan 10, 2009 11:15 am
i dunno, i think that getup would look great on neil's engine. :lol:
PostPosted: Thu Jan 15, 2009 11:07 am
I didn't like the idea of hooking chains directly to the bosses, so I made a bracket out of angle iron:
PostPosted: Fri Sep 11, 2009 5:14 am
pictures and info for current engine lifting post....
PostPosted: Sat Sep 12, 2009 3:37 pm
Shawn,
Dunno if you are renting a lift or own one, but a device called a leveler is an accessory I wouldn't be without. It hooks to the hook on end of the hoist and lets you adjust angle of the engine slidng in merely by you turning a crank to shift the relative center of the device. It is so nice to get er up in the air nice and level, move over the hole, tilit the tranny end down with one hand turning the device, and ease the motor down while you are able to flatten the angle back out. I do it now in one smooth operation and land on the motor mounts too. Much easier than the old slide the hook over way. I bought a Harbor Freight lift and leveler once I figured out a 3 day rental cost the same as the tools.
rock
'64d100
 Post subject: Engine lifting bracket
PostPosted: Fri Oct 30, 2009 5:40 pm
My rebuilt slant is going back in my D100. I left the trans in the truck. Using the 2 tapped holed on the top of the head looks like what I'll be doing. I'm not planning on adding the manifold, dist, or water pump until she's in and bolted down. Does anyone have the dimentions of the factory lifting bracket holes on the lifting end? Is there anything else I need to watch out for? Thanks. Mike
Good gun control is hitting your target repeatedly
PostPosted: Fri Oct 30, 2009 6:12 pm
Don't know if this will help but don't see why not.
PostPosted: Sat Nov 07, 2009 8:12 am
what about after you take the head off? can you just use the head bolts?
PostPosted: Sat Nov 07, 2009 8:47 am
Has anybody tried this with the tranny still attached? Where did you attach it then?
1966 Dart GT
1965 Barracuda
PostPosted: Wed Nov 11, 2009 5:32 am
dadtruck, i will post some new pictures . ronnie
PostPosted: Wed Nov 11, 2009 2:13 pm
Here is my version.I have to get some eye bolts to make it easier.http://i658.photobucket.com/albums/uu31 ... -11002.jpg http://i658.photobucket.com/albums/uu31 ... -11003.jpg The part is off of a 1957 bsa motorcycle.Just had to ream the holes a little.Parts is parts.
PostPosted: Wed Nov 11, 2009 2:28 pm
I did, removed and installed with tranny. I used the same pickup points and a leveller.
vm
Users browsing this forum: Ahrefs [Bot] and 5 guests
