It is currently Sat Jun 13, 2026 6:18 am
 Post subject: Sway bar links
PostPosted: Sat Feb 14, 2009 11:19 am
Some cars have end links that clamp around the strut rod instead of through a tab on the control arm.
Which cars have this feature? C-body? Any late-model stuff with similar design that I can look for in JY?
Thanks for any help.
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Sun Feb 15, 2009 5:09 pm
Never seen any end link connect to a strut rod. Seems that would produce erratic operation as well as playing havoc with alignment. Besides the factory tab riveted into the LCA, I have seen L-shaped tabs that connect to the lower shock mount bolt.
It gets tricky because the factory bars will not align properly with the shock mounted tab and vice versa. At first glance it's hard to tell the bars apart.
You can't fix stupid. - Ron White
PostPosted: Sun Feb 15, 2009 6:13 pm
My '67 Newport had the sway bar connected to the strut rods. I don't know which C-bodies were this way except for that one. There used to be aftermarket sway bars that were set up similarly.
 Post subject: c-body
PostPosted: Sun Feb 15, 2009 8:12 pm
true,I parted out a 73 c body that was like that..
PostPosted: Sun Feb 15, 2009 10:18 pm
My '70 Fury had that set up also. I've seen '73 up B bodys (Satellite's, Coronets, '75-up Cordoba/Charger, maybe Magnums) with the isolated K frame with the links to the strut rods also. Trust me, they work as I went from my stock bar on my Fury to a bar from an ex state patrol car and could tell a huge difference with new bushings and thicker bar.
PostPosted: Mon Feb 16, 2009 2:14 pm
That's what I thought.
I'm putting an f-body sway bar on my 68, and a set of those links would be perfect. Off to scrounge!
O==\=/==O
- Jim Preston
