It is currently Wed May 27, 2026 10:38 am
Post new topic  Reply to topic  [ 69 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Fri Mar 27, 2009 6:36 am
I've got some popcorn and Pepsi here!
:D
PostPosted: Fri Mar 27, 2009 10:29 am
just out of curiousity, why plumb it into the intake rather in line with the hose to the BOV ? I do have to admit thats pretty slick though lol !!
-Mike
PostPosted: Fri Mar 27, 2009 10:31 am
or at the front of the compressor for a more accurate reding of boost ?
-Mike
PostPosted: Fri Mar 27, 2009 11:05 am
There are pressure differences above and below the throttle blades. The engine sees what the intake sees. (if that makes sense) The fuel pressure regulator is plumbed above the throttle blades in the carb hat because of this pressure differential. This is so the fuel pump can overcome the pressure and keep the fuel bowls full rather than the fuel being pushed back into the line.
PostPosted: Sat Apr 04, 2009 4:18 pm
wouldn't a boost referenced FPR do the same thing ?
-Mike
PostPosted: Sat Apr 04, 2009 6:56 pm
Mike, I don't understand your question. A boost referenced FPR is utilized in this application. It receives its signal from the carb hat.
PostPosted: Sat Apr 04, 2009 7:51 pm
my bad had a brain fart about what you said. Hows the build coming ?
-Mike
PostPosted: Sun Apr 05, 2009 5:45 am
Picked up my block last week, dropped my intake off at the powder coaters, dropped off my header and down pipe to have it nickle & chrome plated. I'm still finishing up the tailpipe.
Still deciding if I want to run the old engine with the new turbo and header.
PostPosted: Tue Apr 14, 2009 8:26 pm
Whats Up? Anything new? Did you decide on the old motor or wait for the new? Later
10.74 @ 127.47 mph 1320 ft
6.65 @ 107.80 mph 660 ft
http://www.youtube.com/c/turbo66valiant
Follow on Instagram - turbo66valiant
Facebook - https://www.facebook.com/ryan.peterson.737
PostPosted: Wed Apr 15, 2009 5:21 am
I got the header back from the platers on Monday. I started to shim the valve springs and install 340 springs on the old motor to see if i can get one more pass with it. It will have the new exhaust and new turbo to see how it performs with those change.
Last year, my problem was the stock springs being to weak.
New motor still needs the crank cut (and balancing) but everything else is ready to go.
PostPosted: Wed Apr 15, 2009 7:09 am
Shaker why do you have to shim the valve springs ? Have you taken pics of the plated header ?
-Mike
PostPosted: Wed Apr 15, 2009 7:35 am
No pic yet...there is a pressure ratio that is about 3 to 1 on inefficient turbo engines...meaning if you are putting in 20psi on the intake you will see about 60 psi of back pressure on the exhaust side. I was getting a backfire with the stock /6 springs because they could not close...they have maybe 50-60psi on the seat. I'm shimming the 340 springs to have around 120psi on the seat.
PostPosted: Wed Apr 15, 2009 7:57 pm
I cant wait to see how this all turns out!!
Be sure to post some vids!
PostPosted: Thu Apr 16, 2009 6:31 am
shaker couldn't you get stiffer springs ? are any even available ? By shimming them, will you diminish how much the valve will open and or will it bind at all by being shimmed ?
-Mike
PostPosted: Thu Apr 16, 2009 7:41 am
340 springs will handle it (and they are cheap)...The stock cam does not have much lift either so coil bind is not an issue.
