It is currently Sun Nov 08, 2026 12:45 am
 Post subject: Still no start
PostPosted: Wed Apr 08, 2009 7:33 pm
On my 75 duster I cant get it to turn over. I put a new neutral safety switch and starter relay, but when I turn the key nothing happens. what could be causing this?
Ronnie
http://www.cardomain.com/ride/2714941
PostPosted: Wed Apr 08, 2009 8:36 pm
Site Admin
Have you disconnected the harness and done a ring test on the switch itself?
Automatic transmission? The neutral switch can be damaged if you over-tighten it. Don't know on the manual. Never had one.
CJ
PostPosted: Wed Apr 08, 2009 8:58 pm
Its an auto. I made sure I didnt over tighten it.
Ronnie
PostPosted: Thu Apr 09, 2009 4:21 am
See here.
PostPosted: Tue Apr 21, 2009 3:15 pm
So I got to looking at it and the car will turn over if I put a screw driver on the starter relay. And the starter cranked when I put a screw driver on the wires from the batter. So I am thinking its the ignition switch because the switch will turn even without a key in it.
Ronnie
PostPosted: Tue Apr 21, 2009 3:17 pm
I second the switch. There is definitely something wrong with at least the lock cylinder, and if that is messed up, chances are the ignition switch is messed up too.
Users browsing this forum: Google [Bot] and 0 guests
