It is currently Tue Jun 23, 2026 7:00 am
PostPosted: Wed May 06, 2009 2:27 pm
Restoring 1967 225. After milling mating surfaces of heat riser, surfaces now have about 3/8" gap. What is fix for a proper gasket to vill this void after manifolds are properly aligned and bolted to block? Thanks for ay help.
Bill
PostPosted: Wed May 06, 2009 3:40 pm
A 3/8 gap is a lot... something is not right.
See the manifold installation article for some basic info.
http://www.slantsix.org/articles/Slant_ ... lation.htm
It sounds like the manifold(s) were warped to start with and the "milling" could not correct all the warpage.
There is no gasket that can fill that much gap so you may need to find a different manifold.
PostPosted: Wed May 06, 2009 6:37 pm
Wow, yeah, that's a large gap. This gap is between the bottom of the intake and the top of the exhaust? Sounds like maybe too much milling was done. If that's the case, you'll need to start over with another set of manifolds.
It is very much worth your while to get the good gaskets for the manifolds-to-head and intake-to-exhaust junctions, but even these cannot compensate for a 3/8" gap.
PostPosted: Thu May 07, 2009 12:44 am
 Post subject: Manifold fix
PostPosted: Thu May 07, 2009 11:03 am
Thanks to all who responded, especially with the reference article. I believe the machine shop went overboard. I have a used manifold set on the way, which will also allow me to replace all the missing trangular washers and other hardware. Thanks again!
Users browsing this forum: Greg Ondayko and 2 guests
